I want to configure HAProxy as a tcp pass-through with ssl proxy, but some settings don’t work.
I think ‘ssl verify none’ option at listen directive is work when backend server uses self-signed certificate.
But with ‘ssl verify none’ option with mode tcp, I cannot access backend server with https protocol.
Is it correct behavier?
- This config is not work as https frontend, only http access
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 40000
stats socket /var/lib/haproxy/stats level admin
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 10000
listen https_web
bind *:8443
option log-health-checks
server sv1 sv1:8443 maxconn 512 check check-ssl inter 60s ssl verify none
server sv2 sv2:8443 maxconn 512 backup check check-ssl inter 60s ssl verify none
server sv3 sv3:8443 maxconn 512 backup check check-ssl inter 60s ssl verify none
option httpchk GET /health
http-check expect status 200
- This config is work as https frontend
maxconn 40000
ssl-server-verify none
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 10s
maxconn 10000
listen https_web
bind *:8443
My haproxy build information is below.
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Then you must NOT use the ssl keyword. You can use check-ssl for SSL health checks, that’s fine, but you don’t use the SSL keyword in the server line, because otherwise you’d be encrypting the already encrypted SSL traffic.
lukastribus:
Thank you for your reply.
So, ssl-server-verify none in global directive is the only solution for self-signed ssl health-check ?
Without ‘verify none’ keyword, I cannot get UP status from backend server.
I didn’t understand your answer, and now I understand your answer.
I cannot use ‘ssl’ keyword for ssl health check.
So I only need to delete ssl keyword from server line, and that works, thank you!
@lukastribus
Can I ask you more about this?
If I want to verify my self-signed certificate to healthcheck, like condition below.
how can I configure ?
- ssl pass-thorough
- self-signed certificate
- ssl healthcheck with
http-check expect keyword like status 200, or string success.
I tried following steps, but it didn’t work.
- put self-signed ca-certification at /usr/share/pki/ca-trust-source/anchors/.
- run command
update-ca-trust extract to import certificate (import ca to /etc/ssl/certs/ca-bundle.trust.crt)
- run command
ln -s /etc/ssl/certs/ca-bundle.trust.crt /etc/pki/CA/certs/. to place certificate file in th openssl related path
You need to specify the ca with the ca-file option.
Thank you for your reply,
I tried ca-file, or crt option. but didn’t work.
Anythink incorrect in the config below?
<snip>
<snip>
listen foo
bind *:443
option httpchk GET /healthcheck HTTP/1.1\r\nHost:\ <FQDN1>
http-check expect string success
server bar1 <FQDN1>:443 check inter 30000 rise 1 check-ssl ca-file /etc/pki/CA/certs/ca-bundle.trust.crt
haproxy logged like below:
<snip> failed, reason: Layer6 invalid response, info: "SSL handshake failure", check duration: 3ms, status: 0/1 DOWN.<snip>
Does your backend expect request with SNI? In that case you’d have to specify sni str(FQDN1) and check-sni FQDN1.
Thank you @lukastribus,
Does HAProxy 1.5.18 support those option?
I couldn’t find sni or check-sni option in the haproxy 1.5.18 configuration manual.
Unfortunately you need 1.6 for the sni keyword and 1.8 for the check-sni keyword.
If that is not an option, you probably want to take a look at the backend server and relax this requirement.
I see, thank you very much.
I’ll try update haproxy and sni / check-sni option.
@lukastribus, our certificate did not use SNI, only Subject Alternative Name and Subject Key I dentifier.
Is there any idea about this error?
SNI has nothing to do with the certificate, it has to do with the server HTTPS configuration. What’s the output of:
curl -vk https://fqdn1/healthcheck
openssl s_client -connect example.com:443
Thank you for your advice @lukastribus,
$ curl -kv https://FQDN2/healthcheck
* About to connect() to FQDN2 port 443 (#0)
* Trying 10.101.4.141...
* Connected to FQDN2 (10.101.4.141) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* skipping SSL peer certificate verification
* SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
* Server certificate:
* subject: CN=*.DOMAIN,O=Example,ST=example,C=example
* start date: Feb 23 00:59:19 2018 GMT
* expire date: Feb 16 00:59:19 2048 GMT
* common name: *.DOMAIN
* issuer: CN=CA_example,OU=CA,O=Example,L=Example,ST=example,C=example
> User-Agent: curl/7.29.0
> Host: FQDN2
> Accept: */*
< HTTP/1.1 200 OK
< Date: Fri, 09 Mar 2018 03:57:14 GMT
< Content-Type: application/json
< Content-Length: 20
< Connection: keep-alive
< Host: FQDN2
< X-Forwarded-For: 10.101.4.137
< X-Forwarded-Port: 443
< X-Forwarded-Proto: https
< User-Agent: curl/7.29.0
< Accept: */*
* Connection #0 to host FQDN2 left intact
{"status":"success"}
$ openssl s_client -connect FQDN2:443
CONNECTED(00000003)
depth=0 C = example, ST = example, O = Example, CN = *.DOMAIN
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
Certificate chain
0 s:/C=example/ST=example/O=Example/CN=*.DOMAIN
i:/C=example/ST=example/L=Example/O=Example/OU=CA/CN=CA_example
Server certificate
-----BEGIN CERTIFICATE-----
<snip>
-----END CERTIFICATE-----
subject=/C=example/ST=example/O=Example/CN=*.DOMAIN
issuer=/C=example/ST=example/L=Example/O=Example/OU=CA/CN=CA_example
Peer signing digest: SHA512
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 1712 bytes and written 471 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-SHA384
<snip>
Start Time: 1520568631
Timeout : 300 (sec)
Verify return code: 21 (unable to verify the first certificate)
Why FQDN2 now? Please stop replacing all strings, it impossible to help you this way.
sorry I replaced our FQDN to FQDN2, and also domain to DOMAIN.
FQDN2 has servername.DOMAIN.
Is real FQDN necessary to solve this problem?
I don’t know whether that information will be the one to solve this issue. The point is that I don’t have enough information here for me to be able to understand why the SSL handshake fails.
And I will have to ask for more informations as long as I don’t have the information that explains this behavior.
@lukastribus
Everything became clear.
My colleague gave me wrong cafile.
With collect cafile, it works now.
@lukastribus can you comment in which condition we should specify ca-file ? and ca-file is for backend server’s ca-file or haproxy server’s ca-file ?
The ca-file is used for the root certificate storage to verify a certificate that is supplied either by the client (SSL client certificate, ca-file on the bind line) or by the server (SSL certificate, ca-file on the server line).
