Hi Community,
i dont know why, but my haproxy throws me severals time a “SSL handshake failure” like this:
Jul 18 15:35:43 proxy1 haproxy[6477]: 192.168.100.100:51019 [18/Jul/2018:15:35:43.294] www-https/1: SSL handshake failure
Jul 18 15:35:43 proxy1 haproxy[6474]: 192.168.100.100:51020 [18/Jul/2018:15:35:43.294] www-https/1: SSL handshake failure
Jul 18 15:35:43 proxy1 haproxy[6464]: 192.168.100.100:51022 [18/Jul/2018:15:35:43.366] www-https/1: SSL handshake failure
The certificate is correct, valid and contains chain.
Here is my config file:
maxconn 10240
nbproc 8
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
cpu-map 5 4
cpu-map 6 5
cpu-map 7 6
cpu-map 8 7
nbthread 8
cpu-map auto:1/1-8 0-7
stats bind-process 8
stats uri /stats
stats auth admin:admin
timeout connect 50000
#timeout connect 5000
frontend www-http
default_backend www-backend
frontend www-https
bind *:443 ssl crt /etc/ssl/private/cert.full.pem
backend www-backend
balance source
hash-type consistent
http-response set-header Strict-Transport-Security "max-age=15552000; includeSubDomains; preload;"
server Server1 srv1.example.com:80 check cookie Server1
server Server2 srv2.example.com:80 check cookie Server2
server Server3 srv3.example.com:80 check cookie Server3
