I am using HAProxy 1.8.20 with an 2048 bit certificate from Let’s encrypt. SSL labs has confirmed that the certificate is OK (full certificate chain). However, I still get tons of “SSL handshake failures” in my log. I have tried the suggestions from other threads in this forum but they did not solve my issue.
Any ideas what I can do to resolve the issue? Below are the error messages (small clip from system log, haproxy -vv and my haproxy.conf). Any help would really be appreciated!
Fri Sep 20 06:12:43 2019 local0.info haproxy[13893]: 2401:7400:c802:925e:190:75bb:1f07:55f2:58170 [20/Sep/2019:06:12:43.877] ssl_termination/1: Connection closed during SSL handshake
Fri Sep 20 06:12:43 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50590 [20/Sep/2019:06:12:43.889] ssl_termination/1: SSL handshake failure
Fri Sep 20 06:12:43 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50592 [20/Sep/2019:06:12:43.955] ssl_termination/1: SSL handshake failure
Fri Sep 20 06:12:44 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50594 [20/Sep/2019:06:12:44.014] ssl_termination/1: SSL handshake failure
Fri Sep 20 06:12:44 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50596 [20/Sep/2019:06:12:44.044] ssl_termination/1: SSL handshake failure
Fri Sep 20 06:12:44 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50598 [20/Sep/2019:06:12:44.150] ssl_termination/1: SSL handshake failure
Fri Sep 20 06:12:44 2019 local0.info haproxy[13893]: ::ffff:192.168.1.233:50600 [20/Sep/2019:06:12:44.175] ssl_termination/1: SSL handshake failure
haproxy -vv
HA-Proxy version 1.8.20-1 2019/06/27
Copyright 2000-2019 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = x86_64-openwrt-linux-musl-gcc
CFLAGS = -Os -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -iremap/mnt/data/share/data/software/openwrt/build_dir/target-x86_64_musl/haproxy-ssl/haproxy-1.8.20:haproxy-1.8.20 -Wformat -Werror=format-security -fpic -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -DBUFSIZE=16384 -DMAXREWRITE=1030 -DSYSTEM_MAXCONN=165530
OPTIONS = USE_LINUX_SPLICE=1 USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_ZLIB=yes USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_TFO=1
maxconn = 165530, bufsize = 16384, maxrewrite = 1030, maxpollevents = 200
Built with OpenSSL version : OpenSSL 1.0.2s 28 May 2019
Running on OpenSSL version : OpenSSL 1.0.2s 28 May 2019
Built with PCRE version : 8.41 2017-07-05
Running on PCRE version : 8.41 2017-07-05
PCRE library supports JIT : no (libpcre build without JIT?)
haproxy.conf
# Log events to a remote syslog server at given address using the
# specified facility and verbosity level. Multiple log options
# are allowed.
#log 10.0.0.1 daemon info
log /dev/log local0 debug
# Specifiy the maximum number of allowed connections.
maxconn 20480
# Raise the ulimit for the maximum allowed number of open socket
# descriptors per process. This is usually at least twice the
# number of allowed connections (maxconn * 2 + nb_servers + 1) .
ulimit-n 65535
# Drop privileges (setuid, setgid), default is "root" on OpenWrt.
uid 0
gid 0
# Perform chroot into the specified directory.
#chroot /var/run/haproxy/
# Daemonize on startup
nosplice
# Enable debugging
#debug
# Spawn given number of processes and distribute load among them,
# used for multi-core environments or to circumvent per-process
# limits like number of open file descriptors. Default is 1.
nbproc 2
nbproc 1
nbthread 4
cpu-map auto:1/1-4 0-3
# Default parameters
# Default timeouts
timeout connect 3m
timeout client 60m # timeout in ms
timeout server 60m # timeout in s?
timeout http-keep-alive 60m # timeout in s
maxconn 3000
frontend ssl_termination
bind :::443 v4v6 ssl crt /mnt/container/datadir/certificate/haproxy/ alpn h2,http/1.1
# Serve an internal statistics page on /stats:
#stats enable
#stats uri /stats
# Enable HTTP basic auth for the statistics:
#stats realm HA_Stats
#stats auth username:password
default_backend bk_kopano
acl host_app1 hdr(host) -i one.xxx.xxx
acl host_app2 hdr(host) -i two.xxx.xxx
use_backend bk_app1 if host_app1
use_backend bk_app2 if host_app2
default_backend bk_app2
backend bk_app1
#redirect scheme https if !{ ssl_fc }
http-response del-header X-Varnish
http-response del-header X-Varnish-Cache
http-response del-header X-Varnish-Server
http-response del-header X-Cache
server app1 192.168.1.200:6081 check
backend bk_app2
server app2 192.168.1.220:80 check
