Hi we are using haproxy 2.1.4 as SSL terminator between our own client and server machines(High load machines, always busy) and also requests will be a mix of http/1.1 and http/2.0. We are facing lots of SSL handshake failure in front end. I have enabled proxy logs using rsyslog and get following errors,
Aug 5 18:55:35 localhost haproxy[40308]: 127.0.0.1:55442 [05/Aug/2020:18:55:35.364] frontend/1: SSL handshake failure Aug 5 18:56:20 localhost haproxy[40308]: 204.xx.xx.xx:45474 [05/Aug/2020:18:56:16.761] frontend/1: Connection closed during SSL handshake Aug 5 18:56:22 localhost haproxy[40308]: 204.xx.xx.xx:52088 [05/Aug/2020:18:56:19.403] frontend/1: Connection closed during SSL handshake Aug 5 18:56:33 localhost haproxy[40308]: 127.0.0.1:42470 [05/Aug/2020:18:56:33.933] frontend/1: SSL handshake failure Aug 5 18:56:33 localhost haproxy[40308]: 127.0.0.1:42472 [05/Aug/2020:18:56:33.944] frontend/1: SSL handshake failure
Few of the requests have source Ip as 127.0.0.1 but we are doing a plain text connection between proxy and backend as a proxy is SSL terminator here, I could not get detailed logs out of haproxy, my configurations are as follows,
global log 127.0.0.1 local2 chroot /var/lib/haproxy maxconn 200000 user test group testsending daemon tune.ssl.cachesize 200000 #tune.h2.max-concurrent-streams 10 ssl-dh-param-file /etc/haproxy/dhparam.pem #Default SSL material locations ca-base /etc/ssl/certs crt-base /etc/ssl/private #Obtained from https://mozilla.github.io/server-side-tls/ssl-config-generator/?server=haproxy ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384 ssl-default-bind-ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 ssl-default-bind-options no-sslv3 no-tlsv10 no-tlsv11 ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384 ssl-default-server-ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 ssl-default-server-options no-sslv3 no-tlsv10 no-tlsv11 defaults log global maxconn 20000 mode http option httplog option dontlog-normal option logasap retries 3 retry-on all-retryable-errors option log-separate-errors timeout connect 5s timeout client 60s timeout server 450s frontend frontend_haproxy option forwardfor capture request header MONITORID len 64 capture response header MONITORID len 64 log-format "%ci:%cp\ [%t]\ %f\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ Reqid:%hr\ Resid:%hs\ %{+Q}r\ %sslv\ %sslc" bind *:8088 ssl crt /etc/haproxy/haproxy.pem alpn h2,http/1.1 default_backend backend_eumagent backend backend_eumagent timeout server 420000 fullconn 2000 server tomcat localhost:9099 check
and output of haproxy -vv as,
HA-Proxy version 2.1.4 2020/04/02 - https://haproxy.org/ Status: stable branch - will stop receiving fixes around Q1 2021. Known bugs: http://www.haproxy.org/bugs/bugs-2.1.4.html Build options : TARGET = linux-glibc CPU = generic CC = gcc CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1 Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS Default settings : bufsize = 16384, maxrewrite = 1024, maxpollevents = 200 Built with multi-threading support (MAX_THREADS=64, default=6). Built with OpenSSL version : OpenSSL 1.1.1c 28 May 2019 Running on OpenSSL version : OpenSSL 1.1.1c 28 May 2019 OpenSSL library supports TLS extensions : yes OpenSSL library supports SNI : yes OpenSSL library supports : TLSv1.0 TLSv1.1 TLSv1.2 TLSv1.3 Built with network namespace support. Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT IP_FREEBIND Built with PCRE version : 8.32 2012-11-30 Running on PCRE version : 8.32 2012-11-30 PCRE library supports JIT : no (USE_PCRE_JIT not set) Encrypted password support via crypt(3): yes Built with zlib version : 1.2.7 Running on zlib version : 1.2.7 Compression algorithms supported : identity("identity"), deflate("deflate"), raw-deflate("deflate"), gzip("gzip") Available polling systems : epoll : pref=300, test result OK poll : pref=200, test result OK select : pref=150, test result OK Total: 3 (3 usable), will use epoll. Available multiplexer protocols : (protocols marked as <default> cannot be specified using 'proto' keyword) h2 : mode=HTTP side=FE|BE mux=H2 fcgi : mode=HTTP side=BE mux=FCGI <default> : mode=HTTP side=FE|BE mux=H1 <default> : mode=TCP side=FE|BE mux=PASS Available services : none Available filters : [SPOE] spoe [CACHE] cache [FCGI] fcgi-app [TRACE] trace [COMP] compression
We send requests to haproxy from apache(http1.1) and jetty(http2) httpclients using java 8 and our backend is an apache tomcat 9.0.30+ running using java 11. All our machines are centos 7.x versions.
Kindly help me to debug this issue. Thanks in advance
