Nov 18 12:37:05 mail haproxy[126258]: xx.yy.zzz.vvv:63965 [18/Nov/2023:12:37:05.468] http-in/2: SSL handshake failure (error:0A0000EA:SSL routines::callback failed)
Nov 18 12:47:14 mail haproxy[126258]: Proxy http-in stopped (cumulated conns: FE: 866, BE: 0).
Nov 18 12:47:14 mail haproxy[126258]: [WARNING] (126258) : Proxy letsencrypt-backend stopped (cumulated conns: FE: 0, BE: 0).
Nov 18 12:47:14 mail haproxy[126258]: message repeated 2 times: [ Proxy http-in stopped (cumulated conns: FE: 866, BE: 0).]
Nov 18 12:47:14 mail haproxy[126258]: Proxy letsencrypt-backend stopped (cumulated conns: FE: 0, BE: 0).
Nov 18 12:47:14 mail haproxy[126258]: [WARNING] (126258) : Proxy website-static stopped (cumulated conns: FE: 0, BE: 205).
Nov 18 12:47:14 mail haproxy[126258]: Proxy website-static stopped (cumulated conns: FE: 0, BE: 205).
Nov 18 12:47:14 mail haproxy[126258]: [WARNING] (126258) : Proxy website stopped (cumulated conns: FE: 0, BE: 134).
Nov 18 12:47:14 mail haproxy[126258]: Proxy website stopped (cumulated conns: FE: 0, BE: 134).
Nov 18 12:47:14 mail haproxy[126258]: [WARNING] (126258) : Proxy cmssite stopped (cumulated conns: FE: 0, BE: 3).
Nov 18 12:47:14 mail haproxy[126258]: Proxy cmssite stopped (cumulated conns: FE: 0, BE: 3).
Most probably some misconfiguration.
Here is my config:
pidfile /var/run/haproxy
stats socket /var/run/haproxy/admin.sock level admin mode 660
setenv ACCOUNT_THUMBPRINT 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
maxconn 4000
ca-base /etc/ssl/apache2/certs
crt-base /etc/ssl/apache2/private
ssl-dh-param-file /etc/haproxy/dhparams.pem
ssl-skip-self-issued-ca
compression algo gzip
compression type text/html text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy application/atom+xml application/javascript application/x-javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest
option dontlog-normal
option httpclose
frontend http-in
bind *:443 ssl crt /etc/haproxy/certs/ strict-sni
bind quic4@0.0.0.0:443 name quic443 ssl crt /etc/haproxy/certs/www.mydomain.org.pem proto quic alpn h3,h3-29,h3-28,h3-27 npn h3,h3-29,h3-28,h3-27 allow-0rtt curves secp521r1:secp384r1
http-response add-header alt-svc 'h3=":443"; ma=7200,h3-29=":443"; ma=7200,h3-Q050=":443"; ma=7200,h3-Q046=":443"; ma=7200,h3-Q043=":443"; ma=7200,quic=":443"; ma=7200'
http-request return status 200 content-type text/plain lf-string "%[path,field(-1,/)].${ACCOUNT_THUMBPRINT}\n" if { path_beg '/.well-known/acme-challenge/' }
# Redirect if HTTPS is *not* used
default_backend website
log /dev/log local2 debug
acl is_static path_beg /export/ /opencms/ /resources/ /javadoc/ /VAADIN/ /workplace /opencms-login/
acl is_website hdr_beg(host) -i www.mydomain.org
acl is_cmssite hdr_beg(host) -i cms.mydomain.org
use_backend website-static if is_website is_static
use_backend website if is_website
use_backend cmssite if is_cmssite
server www.mydomain.org 127.0.0.1:8080
backend website
http-request set-path /opencms%[path]
backend cmssite
server cms.mydomain.org 127.0.0.1:8082
What is wrong?
