Haproxy 3.0.6 - Backend ssl handshake failure
I am just trying out simple haproxy configuration in http mode where i want https connection between client and haproxy as well as between haproxy and my backend server.
I am having this issue of ssl handshake failure between haproxy and backend server and can’t quite figure it out what is wrong with the configuration. I am running haproxy on my docker container.
This is my haproxy -vv
HAProxy version 3.0.6-c2c0090 2024/11/07 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2029.
Known bugs: http://www.haproxy.org/bugs/bugs-3.0.6.html
Running on: Linux 5.10.102.1-microsoft-standard-WSL2 #1 SMP Wed Mar 2 00:30:59 UTC 2022 x86_64
  TARGET  = linux-glibc
  CC      = cc
  CFLAGS  = -O2 -g -fwrapv
  OPTIONS = USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1
  DEBUG   =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC -OPENSSL_WOLFSSL -OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC -QUIC_OPENSSL_COMPAT +RT +SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=4).
Built with OpenSSL version : OpenSSL 3.0.15 3 Sep 2024
Running on OpenSSL version : OpenSSL 3.0.15 3 Sep 2024
Built with Lua version : Lua 5.4.4
Built with PCRE2 version : 10.42 2022-12-11
Built with gcc compiler version 12.2.0
        [BWLIM] bwlim-in
        [BWLIM] bwlim-out
        [FCGI] fcgi-app
The below is my haproxy configuration
# haproxy.cfg
    stats socket *:1999 level admin
    server-state-file /usr/local/etc/haproxy/haproxy.state
    maxconn 4096
    timeout connect 5000ms
    timeout client  50000ms
    timeout server  50000ms
frontend prometheus
  bind *:8405
  http-request use-service prometheus-exporter
  no log
frontend http_front
    bind *:443 ssl crt /run/secrets/ssl_cert
    acl path_fact path_beg /fact
    # deny request on missing auth header
    http-request deny content-type 'text/html' string 'Missing Authorization HTTP header' if !{ req.hdr(authorization) -m found } !path_chat !path_fact
    # variables
    http-request set-var(txn.alg) http_auth_bearer,jwt_header_query('$.alg')    # get header part of the JWT
    http-request set-var(txn.exp) http_auth_bearer,jwt_payload_query('$.exp','int') # get payload part of the JWT
    http-request set-var(txn.now) date() # get current date
    # check if token is expired
    http-request deny content-type 'text/html' string 'JWT has expired' if { var(txn.exp),sub(txn.now) -m int lt 0 }
    # acl for path match
    acl path_httpbin path_beg /httpbin
    acl jwt_valid_key_httpbin http_auth_bearer,jwt_verify(txn.alg,"/run/secrets/public_key_three") -m int 1
    http-request deny content-type 'text/html' string 'Invalid JWT signature for httpbin' if path_httpbin !jwt_valid_key_httpbin
    use_backend cat_fact if path_fact
    use_backend httpbin_backend if path_httpbin
    default_backend be_test
    http-request replace-path ^/httpbin(/.*)$ \1
    server httpbin httpbin.org:443 ssl verify none check
backend cat_fact
    server fact catfact.ninja:443 ssl verify none check
backend be_test
    http-request return status 200 content-type 'text/html' string 'Hello! You are authorized'
the httpbin_backend is working fine but the cat_fact backend is throwing error given below
[WARNING]  (8) : Server cat_fact/fact is DOWN, reason: Layer6 invalid response, info: "SSL handshake failure", check duration: 29ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT]    (8) : backend 'cat_fact' has no server available!
backend cat_fact has no server available!
i am not sure why it is working for httpbin_backend and not for cat_fact backend. I am using these third party domains for test purpose.
My guess is that haproxy isnt sending the SNI data in the TLS handshake, and catfact requires it. I haven’t played with this myself but check out ‘sni’ and ‘check-sni’ keywords that you apply to the server
Yes you are correct it worked after introducing sni and check-sni in my server. It also required host header.
Thank you for your answer.
