We are trying to migrate nginx proxy servers to ha proxy but we are experiencing some issues. We get the following error
4431185516:error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure:s3_pkt.c:1498:SSL alert number 40 4431185516:error:140790E5:SSL routines:ssl23_write:ssl handshake failure:s23_lib.c:177:
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:AES256+EECDH:AES256+EDH:DHE-RSA-AES256-SHA
ssl-default-bind-options no-tlsv10 no-tlsv11 no-tls-tickets
# ssl-default-bind-options no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
# ssl-default-server-options no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
ssl-default-server-options no-tlsv10 no-tlsv11 no-tls-tickets
ssl-default-server-ciphers EECDH+AESGCM:EDH+AESGCM:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:AES256+EECDH:AES256+EDH:DHE-RSA-AES256-SHA
timeout connect 4s
timeout client 60s
timeout server 60s
option httpchk
default-server init-addr none
resolvers dnsserver1
nameserver opendns ${DNS_ADDR}:53
hold valid 1s
frontend http
bind *:443 ssl crt /etc/ssl/haproxy.pem ca-file /etc/ssl/cacert.pem verify required accept-proxy alpn http/1.0,h2,http/1.1
timeout client 1m
log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %hs\ {%[ssl_c_verify],%[ssl_c_s_dn],%[ssl_c_i_dn]}\ %{+Q}r,\ %{+Q}[ssl_c_der,base64]
http-request set-header X-Haproxy-Current-Date %T
http-request set-header X-SSL %[ssl_fc]
http-request set-header X-SSL-Session_ID %[ssl_fc_session_id,hex]
http-request set-header X-SSL-Client-Verify %[ssl_c_verify]
http-request set-header X-SSL-Client-DN %{+Q}[ssl_c_s_dn]
http-request set-header X-SSL-Client-CN %{+Q}[ssl_c_s_dn(cn)]
http-request set-header X-SSL-Issuer %{+Q}[ssl_c_i_dn]
http-request set-header X-SSL-Client-NotBefore %{+Q}[ssl_c_notbefore]
http-request set-header X-SSL-Client-NotAfter %{+Q}[ssl_c_notafter]
http-request set-header X-SSL-Subject-DN %{+Q}[ssl_c_s_dn]
http-request set-header X-SSL-Issuer-DN %{+Q}[ssl_c_i_dn]
http-request set-header X-SSL-Client-Subject-DN %{+Q}[ssl_c_s_dn]
http-request set-header X-SSL-Client-Issuer-DN %{+Q}[ssl_c_i_dn]
http-request set-header X-SSL-Cipher %[ssl_fc_cipher]
http-request set-header X-SSL-Protocol %[ssl_fc_protocol]
http-request set-header X-Forwarded-Proto \ https
default_backend srvs_api
backend srvs_api
option httpchk HEAD /
http-check expect status 503
server api.0 api.core."$DNS_DOMAIN":443 resolvers dnsserver1 check inter 2000 rise 2 fall 5 ssl crt /etc/ssl/haproxy_client.pem ca-file /etc/ssl/service-server-cacert.pem
server api.1 api.core."$DNS_DOMAIN":443 resolvers dnsserver1 check inter 2000 rise 2 fall 5 ssl crt /etc/ssl/haproxy_client.pem ca-file /etc/ssl/service-server-cacert.pem
server api.2 api.core."$DNS_DOMAIN":443 resolvers dnsserver1 check inter 2000 rise 2 fall 5 ssl crt /etc/ssl/haproxy_client.pem ca-file /etc/ssl/service-server-cacert.pem
timeout server 1m
http-request set-header X-Forwarded-By %[var(proc.xforwardedby)]
http-request set-header X-Forwarded-For "${DOCKERIP}:%[dst_port]"
http-request set-header X-Client-IP %[var(proc.xclientip)]
This is the output of the server startup
HA-Proxy version 2.0.5 2019/08/16 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Running on OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Built with PCRE2 version : 10.33 2019-04-16
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services :
prometheus-exporter
Proxy http started.
Proxy srvs_api started.
[NOTICE] 252/055404 (1) : New worker #1 (33) forked
[WARNING] 252/055404 (33) : srvs_api/api.0 changed its IP from to 172.28.4.75 by dnsserver1/opendns.
[WARNING] 252/055404 (33) : Server srvs_api/api.0 ('api.core.qa.au.littlepay.com') is UP/READY (resolves again).
[WARNING] 252/055404 (33) : Server srvs_api/api.0 administratively READY thanks to valid DNS answer.
[WARNING] 252/055404 (33) : srvs_api/api.1 changed its IP from to 172.28.5.93 by DNS cache.
[WARNING] 252/055404 (33) : Server srvs_api/api.1 ('api.core.qa.au.littlepay.com') is UP/READY (resolves again).
[WARNING] 252/055404 (33) : Server srvs_api/api.1 administratively READY thanks to valid DNS answer.
[WARNING] 252/055404 (33) : srvs_api/api.2 changed its IP from to 172.28.6.224 by DNS cache.
[WARNING] 252/055404 (33) : Server srvs_api/api.2 ('api.core.qa.au.littlepay.com') is UP/READY (resolves again).
[WARNING] 252/055404 (33) : Server srvs_api/api.2 administratively READY thanks to valid DNS answer.
The log is shown as follows:
XX.XX.XX.XX:3524 [10/Sep/2019:07:19:16.571] http/1: SSL handshake failure
It would be really appreciated any help ![]()
Nestor
