Frontend mode tcp with ssl not work
Hi all,
I want to use haproxy to reverse proxy for a postgresql service
192.168.7.112 is haproxy (haproxy run as container) (postgres.mydomain.com resolve dns = 192.168.7.112)
192.168.0.205 is postgresql server
haproxy.cfg
    log         127.0.0.1 local2 info
    maxconn 4096
    timeout client 1m
    timeout server 1m
frontend postgres_frontend
    bind *:5434 ssl crt /etc/ssl/certs/mycert.pem
    #bind *:5434
    default_backend postgres_backend
    #option tcp-check
    server postgres1 192.168.0.205:5434
mycert.pem is my valid wildcard certificate for *.mydomain.com with format
-----BEGIN CERTIFICATE-----
<Server Certificate>
-----END CERTIFICATE-----
<Intermediate Certificate>
-----BEGIN PRIVATE KEY-----
<Private Key>
-----END PRIVATE KEY-----
from a psql client on differrent host
psql "host=postgres.mydomain.com port=5434 dbname=mydb user=postgres password=***** sslmode=require"
psql: error: connection to server at "postgres.mydomain.com" (192.168.7.112), port 5434 failed: server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
If I remove ssl from haproxy frontend config
    #bind *:5434 ssl crt /etc/ssl/certs/mycert.pem
    bind *:5434
and connect again without ssl , it works ok
psql "host=postgres.mydomain.com port=5434 dbname=mydb user=postgres password=***** sslmode=disable"
please give me some advice, thank you very much.
This will never work, postgresql negotiates SSL during the postgresql handshake (STARTSSL or explicit SSL), there is no vanilla SSL session (implicit SSL), so haproxy will never be able to do this.
thank you very much
So the solution is to enable ssl for posgresql and configure haproxy to run passthrough tcp mode?
Yes, if you keep haproxy in passthrough tcp mode, it will work just fine.
