I want to make a simple balancer. There are two master-slave posgresql servers and a separate Haproxy server.
Configured, but Haproxy sees added servers as down
My haproxy.cfg
retries 2
timeout client 30m
timeout connect 4s
timeout server 30m
timeout check 5s
bind *:7000
stats uri /
listen postgres
bind *:3307
timeout client 10800s
timeout server 10800s
tcp-check expect string master\ is\ running
option tcp-check
option allbackups
server 172.16.107.100 172.16.107.100:5432 check port 5432
server 172.16.107.101 172.16.107.101:5432 check
