I have haproxy on a Intel® Xeon® CPU E5-2407 v2 @ 2.40GHz. It has one CPU with 4 cores.
The machine has two network interfaces eth0 and eth1 as bond0, active/passive. These are the interrupts stats:
# grep eth /proc/interrupts
81: 212387530 0 0 0 IR-PCI-MSI-edge eth0-tx-0
82: 853666386 0 0 0 IR-PCI-MSI-edge eth0-rx-1
83: 144560404 0 0 0 IR-PCI-MSI-edge eth0-rx-2
84: 144618581 0 0 0 IR-PCI-MSI-edge eth0-rx-3
85: 157761343 0 0 0 IR-PCI-MSI-edge eth0-rx-4
86: 193216 0 0 0 IR-PCI-MSI-edge eth1-tx-0
87: 707629860 0 0 0 IR-PCI-MSI-edge eth1-rx-1
88: 85622 0 0 0 IR-PCI-MSI-edge eth1-rx-2
89: 8121 0 0 0 IR-PCI-MSI-edge eth1-rx-3
90: 12673724 0 0 0 IR-PCI-MSI-edge eth1-rx-4
As you can see, IRQ happen on CPU 0, there’s no irqbalance. Also I haven’t done any manual IRQ pinning, it was like that by default. So I chose to put 3 haproxy on CPU 1, 2, 3 like this:
nbproc 3
cpu-map 1 1
cpu-map 2 2
cpu-map 3 3
I’ve checked that the haproxy processes actually belong to CPU 1, 2, 3 by reading /proc/$pid/task/*/status .
Problem
The number of connections, and hence the CPU usage, is not balanced among the three haproxy processes:
# ls /proc/23183/fd|wc -l
2381
# ls /proc/23184/fd|wc -l
636
# ls /proc/23185/fd|wc -l
626
What could I possibly doing wrong? What could be the problem? I’ve also tried with 4 processes pinned to CPU 0, 1, 2, 3 with a similar result. One process has most of connections compared to the other processes, and it’s always the lowest pid (first child forked I guess).
