Hello, while testing a new haproxy cluster i’m now facing an issue of poor performance.
I’ll try to provide as much details as i can about the HW, Kernel and haproxy configuration
The main issues i see is are :
- high cpu usage (100%) of ksoftirqd
- haproxy is 100% utilized very fast with just
Haproxy version:
/ # haproxy -vv
HA-Proxy version 1.9.6 2019/03/29 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.1.1b 26 Feb 2019
Running on OpenSSL version : OpenSSL 1.1.1b 26 Feb 2019
Built with PCRE version : 8.42 2018-03-20
Running on PCRE version : 8.42 2018-03-20
h2 : mode=HTX side=FE|BE
h2 : mode=HTTP side=FE
: mode=TCP|HTTP side=FE|BE
OS and Kernel:
Ubuntu 18.04.2
Kernel: 4.15.0-46-generic
HW:
Manufacturer: Dell Inc.
Product Name: PowerEdge R640
CPU:
2X Version: Intel(R) Xeon(R) Gold 5115 CPU @ 2.40GHz
kernel CPU map:
cat /sys/bus/cpu/devices/cpu0/topology/core_siblings_list
0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38
cat /sys/bus/cpu/devices/cpu1/topology/core_siblings_list
1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31,33,35,37,39
Sysctl and security limits:
ulimits:
- nofile:250000:250000
sysctls:
net.ipv4.conf.all.rp_filter: 1
net.core.somaxconn: 65534
net.core.netdev_max_backlog: 100000
net.ipv4.ip_local_port_range: 1025 65000
net.ipv4.conf.all.send_redirects: 1
net.ipv4.ip_nonlocal_bind: 1
net.ipv4.tcp_abort_on_overflow: 0
net.ipv4.tcp_fin_timeout: 10
net.ipv4.tcp_keepalive_time: 300
net.ipv4.tcp_max_orphans: 262144
net.ipv4.tcp_max_syn_backlog: 100000
net.ipv4.tcp_max_tw_buckets: 262144
net.ipv4.tcp_rmem: 4096 16060 64060
net.ipv4.tcp_wmem: 4096 16384 262144
net.ipv4.tcp_reordering: 3
net.ipv4.tcp_synack_retries: 3
net.ipv4.tcp_syncookies: 1
net.ipv4.tcp_syn_retries: 5
net.ipv4.tcp_timestamps: 0
net.ipv4.tcp_tw_reuse: 1
net.netfilter.nf_conntrack_max: 10485760
net.netfilter.nf_conntrack_tcp_timeout_fin_wait: 30
net.netfilter.nf_conntrack_tcp_timeout_time_wait: 15
Current haproxy configuration (tried with different nbproc/nbthread got the same behavior)
nbproc 1
nbthread 10
# cpu-map auto:1/1-4 0-3
cpu-map odd 1-20
tune.http.logurilen 65535
ssl-default-bind-ciphers TLS13-AES-256-GCM-SHA384:TLS13-AES-128-GCM-SHA256:TLS13-CHACHA20-POLY1305-SHA256:EECDH+AESGCM:EECDH+CHACHA20
ssl-default-bind-options no-sslv3 no-tlsv10 no-tlsv11
maxconn 500000
option abortonclose
timeout http-request 10s
timeout queue 2s
timeout client 2m
timeout server 2m
timeout http-keep-alive 10s
timeout check 5s
maxconn 1000
Network:
eno1np0
eno2np1
The test is done using a simple nginx as backend, and apache banchmark (ab) as client running from another node. i’ve tried different test…
ab -k -r -c 1000 -n 1000000
I’m almost sure this issue has something to do with the Network IRQ
As described in haproxy docs i would like to bind the network interfaces to the same CPU haproxy runs on (CPU0) but to the cores which haproxy does not use according to the map in global configuration.
since haproxy only uses “odd” so all “even” cores should be used by the Network interfaces,
At lease according to my understanding.
Nothing i tries made this work any better,
Need advise on how to optimize the kernel… expecting this HW to handle much more traffic
______________________________________________________________-
Update:
I also tried to run haproxy with nbthread 12 and bind to first 12 even cores
cpu-map even 2-24
Then i tried to set the smp_affinity of the Network IRQ
echo “2” > /proc/irq/43/smp_affinity
echo “8” > /proc/irq/44/smp_affinity
echo “20” > /proc/irq/45/smp_affinity
echo “80” > /proc/irq/46/smp_affinity
echo “200” > /proc/irq/126/smp_affinity
echo “800” > /proc/irq/127/smp_affinity
echo “2000” > /proc/irq/128/smp_affinity
echo “8000” > /proc/irq/129/smp_affinity
Also disabled and removed irq balance service and rebooted.
Still see high ksoftirqd cpu usage and poor haproxy performance…
