Connections stopping after 2,000 connections
Afternoon all, I have read and tested so many things my eyes are bleeding, but basically I had a similar issue with MQTT and mosquitto and have that resolved, but when I test through my HAProxy server, it’s stopping after 2,000 connections (yet direct I can get well over 10k).
I have ulimit -n showing 64k connections for both root and haproxy. When I check the processes I have 3.
/usr/sbin/haproxy-systemd-wrapper -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
/usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds . (2 identical ones).
If I check the 2 that are the same (/proc/ID/limits) I see the following;
Max open files 8000035 8000035 files
but the 1st shows;
Max open files 1024 4096 files
I don’t know if that is the issue, but my haproxy.cfg shows the following;
maxconn 4000000
listen mqtt
bind *:1883
server broker_1 192.168.1.231:1883 check
listen mqtt-swd1
bind *:1884
So, that single server has a public IP which I mentioned, if I go direct with a test app can make over 10k connections, but when I say go through HAProxy, it stops at exactly 2k connections.
This is running on an amazon AWS linux EC2 server (I can really use any distro) but this should be a non issue.
Any help or .02 is appreciated.
Your Global maxconn is way too big and I guess HAProxy falls back to the default 2K value.
Try with a global maxconn at 10K for example and see if you can beat the 2K.
You must have a warning message printed by HAProxy at start up. You should read it.
Note that there is also a default hidden maxconn on the frontend set to 2K as well. You might want to add a maxconn parameter in your frontend/listen sections with a higher value.
https://cbonte.github.io/haproxy-dconv/1.8/configuration.html#4-maxconn
