Theoretical limits for a HAProxy instance
We are performing a lot of load tests, and we hit what we think is an artificial limit of some sort, or a parameter that we are not taking into account (HAProxy config setting, kernel parameter…). We are wondering if there’s a known limit on what HAProxy is able to process, or if someone has experienced something similar, as we are thinking about moving to bigger servers, and we don’t know if we will observe a big difference.
Custom kernel parameters
net.ipv4.ip_local_port_range = "12768    60999"
net.nf_conntrack_max = 5000000
fs.nr_open = 5000000
Output from `haproxy -vv`
HAProxy version 2.6.6-274d1a4 2022/09/22 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2027.
Known bugs: http://www.haproxy.org/bugs/bugs-2.6.6.html
Running on: Linux 5.15.0-53-generic #59-Ubuntu SMP Mon Oct 17 18:53:30 UTC 2022 x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = cc
  CFLAGS  = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
  OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1 USE_PROMEX=1
  DEBUG   = -DDEBUG_STRICT -DDEBUG_MEMORY_POOLS
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL +THREAD +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -ENGINE +GETADDRINFO +OPENSSL -LUA +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with multi-threading support (MAX_THREADS=64, default=32).
Built with OpenSSL version : OpenSSL 3.0.7 1 Nov 2022
Running on OpenSSL version : OpenSSL 3.0.7 1 Nov 2022
Built with gcc compiler version 11.3.0
	[FCGI] fcgi-app
HAProxy config
    log /dev/log len 65535 local0 warning
    stats socket /run/haproxy-admin.sock mode 660 level admin
    maxconn 2000000
    maxconnrate 2500
    maxsslrate 2500
    log     global
    option  dontlognull
    timeout client  120s
    timeout server  120s
frontend stats
    bind *:8404
    stats uri /stats
    stats refresh 10s
frontend k8s-api
    bind *:6443
    timeout client 300s
    default_backend k8s-api
backend k8s-api
    option tcp-check
    timeout server 300s
    default-server inter 10s downinter 5s rise 2 fall 2 slowstart 60s maxconn 500 maxqueue 256 weight 100
    server master01 x.x.x.x:6443 check
    server master02 x.x.x.x:6443 check
    server master03 x.x.x.x:6443 check
    retries 0
frontend k8s-server
    http-request add-header X-Forwarded-Proto http
    http-request add-header X-Forwarded-Port 80
    default_backend k8s-server
backend k8s-server
    default-server inter 10s downinter 5s rise 2 fall 2 check
    server worker01a x.x.x.x:31551 maxconn 200000
    server worker02a x.x.x.x:31551 maxconn 200000
    server worker03a x.x.x.x:31551 maxconn 200000
    server worker04a x.x.x.x:31551 maxconn 200000
    server worker05a x.x.x.x:31551 maxconn 200000
    server worker06a x.x.x.x:31551 maxconn 200000
    server worker07a x.x.x.x:31551 maxconn 200000
    server worker08a x.x.x.x:31551 maxconn 200000
    server worker09a x.x.x.x:31551 maxconn 200000
    server worker10a x.x.x.x:31551 maxconn 200000
    server worker11a x.x.x.x:31551 maxconn 200000
    server worker12a x.x.x.x:31551 maxconn 200000
    server worker13a x.x.x.x:31551 maxconn 200000
    server worker14a x.x.x.x:31551 maxconn 200000
    server worker15a x.x.x.x:31551 maxconn 200000
    server worker16a x.x.x.x:31551 maxconn 200000
    server worker17a x.x.x.x:31551 maxconn 200000
    server worker18a x.x.x.x:31551 maxconn 200000
    server worker19a x.x.x.x:31551 maxconn 200000
    server worker20a x.x.x.x:31551 maxconn 200000
    server worker01an x.x.x.x:31551 maxconn 200000
    server worker02an x.x.x.x:31551 maxconn 200000
    server worker03an x.x.x.x:31551 maxconn 200000
    retries 0
frontend k8s-server-https
    bind *:443 ssl crt /etc/haproxy/certs/
    http-request add-header X-Forwarded-Port 443
    http-request del-header X-SERVER-SNI
    http-request set-header X-SERVER-SNI %[ssl_fc_sni] if { ssl_fc_sni -m found }
    http-request set-var(txn.fc_sni) hdr(X-SERVER-SNI) if { hdr(X-SERVER-SNI) -m found }
    default_backend k8s-server-https
    default-server inter 10s downinter 5s rise 2 fall 2  check no-check-ssl
    server worker01a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker02a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker03a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker04a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker05a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker06a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker07a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker08a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker09a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker10a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker11a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker12a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker13a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker14a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker15a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker16a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker17a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker18a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker19a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker20a x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker01an x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker02an x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    server worker03an x.x.x.x:31445 ssl ca-file /etc/haproxy/ca/ca.crt sni var(txn.fc_sni) maxconn 200000
    retries 0
frontend k8s-nfs-monitor
    bind *:8080
    monitor-uri /health_nfs_cluster
    acl k8s_server_down nbsrv(k8s-server) le 2
    acl nfs_down nbsrv(nfs) lt 1
    monitor fail if nfs_down || k8s_server_down
backend nfs
    default-server inter 5s downinter 2s rise 1 fall 2
        server nfs01 x.x.x.x:2049 check
frontend k8s-cluster-monitor
    bind *:8081
    monitor-uri /health_cluster
    monitor fail if k8s_server_down
When trying to perform the load test in production, we observe that we can sustain 200k connections, and 10k rps, with a load1 of about 10. The maxsslrate and maxsslconn are maxed out, but we handle the requests fine, and we don’t return 5xx. Once we increase the load just a bit and hit 11k rps and about 205k connections, we start to return 5xx and we rapidly decrease the load, as these are tests against production.
Production server specs
Hosted on bare metal
CPU: AMD Ryzen 7 3700X 8-Core Processor (16 threads)
RAM: DDR4 64GB (2666 MT/s)
Production Prometheus metrics
haproxy_process_current_connections
rate(haproxy_process_requests_total[2m])
haproxy_process_idle_time_percent
haproxy_process_current_ssl_rate
haproxy_process_current_connection_rate
node_load1
node_nf_conntrack_entries
When trying to perform a load test with synthetic tests using k6 as our load generator against staging, we are able to sustain 750k connections, with 20k rps. The load generator has a ramp-up time of 120s to achieve the 750k connections, as that’s what we are trying to benchmark.
Staging server specs
CPU: AMD Ryzen 5 3600 6-Core Processor (12 threads)
RAM: DDR4 64GB (3200 MT/s)
Staging Prometheus metrics
node_load1
~3 years ago we ran into some hard limits on connections coming into a frontend in haproxy v1.8. we worked around it by setting up multiple identical frontends in the config running on different ports, and then put a load balancer in front of the haproxy that spread the traffic across the ports.
i don’t recall the exact underlying technical limitation that was at the root cause of this and we haven’t been doing it with our current config, so this may or may not be useful information :slight_smile:
Seems like OpenSSL was the culprit here. We downgraded to 1.1.1s (from 3.0.7), and we now see much better numbers. HAProxy seems to scale linearly with the available resources.
