Hey folks,
I’m using filestash (GitHub - mickael-kerjean/filestash: 🦄 A modern web client for SFTP, S3, FTP, WebDAV, Git, Minio, LDAP, CalDAV, CardDAV, Mysql, Backblaze, ...) with docker, default listening port is 8334, working great locally and on the same network => http://192.168.1.100:8334
Haproxy is intalled on Debian (not into a docker container)
I made my content delivery rules like all my others self hosted services:
global log /dev/log local0 log /dev/log local1 notice chroot /var/lib/haproxy stats socket /run/haproxy/admin.sock mode 660 level admin expose-fd listeners stats timeout 30s user haproxy group haproxy daemon # Default SSL material locations ca-base /etc/ssl/certs crt-base /etc/ssl/private ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS ssl-default-bind-options no-sslv3 tune.ssl.default-dh-param 2048 defaults log global mode http option httplog option dontlognull timeout connect 5000 timeout client 50000 timeout server 50000 errorfile 400 /etc/haproxy/errors/400.http errorfile 403 /etc/haproxy/errors/403.http errorfile 408 /etc/haproxy/errors/408.http errorfile 500 /etc/haproxy/errors/500.http errorfile 502 /etc/haproxy/errors/502.http errorfile 503 /etc/haproxy/errors/503.http errorfile 504 /etc/haproxy/errors/504.http frontend http bind :5080 option http-server-close option forwardfor frontend https bind :5443 ssl crt /etc/ssl/private/mykeyxxxxxxx.pem option http-server-close option forwardfor rspirep ^Location:\ http://(.*)$ Location:\ https://\1 rspadd Strict-Transport-Security:\ max-age=31536000;\ includeSubDomains use_backend filestash if { hdr_beg(Host) -i filestash. } backend filestash server filestash 127.0.0.1:8334 check
But it doesnt work, page return to me a 504 Gateway Time-out whe using external address: https://filestash.domain.com
Haproxy log:
Feb 4 15:49:56 haproxy[17071]: 192.168.1.254:50115 [04/Feb/2021:15:49:06.584] https~ filestash/filestash 0/0/0/-1/50001 504 195 - - sH-- 1/1/0/0/0 0/0 “GET / HTTP/1.1”
Feb 4 15:50:46 haproxy[17071]: 192.168.1.254:50177 [04/Feb/2021:15:49:56.775] https~ filestash/filestash 0/0/0/-1/50002 504 195 - - sH-- 1/1/0/0/0 0/0 “GET /favicon.ico HTTP/1.1”
(I’m NATed, 192.168.1.254 is my default gateway)
I know Docker create it’s own network rules and interfaces and that can be messy, but if it works locally with http://192.168.1.100:8334, why it’s not working with Haproxy in front ?
I have no issue at all with my others hosted services (no docker) when using same settings in Haproxy configuration.
I guess something is wrong with my Haproxy configuration when using it to delivery content to a docker container ?
Thank you ![]()
