How redirect https://www.example.com to docker container
Hello , i am new to haproxy and i tried this configuration to redirect https://example.com to my docker host . but when i try i get error of “Secure Connection Failed SL_ERROR_RX_RECORD_TOO_LONG” in bowser.
frontend http
  bind *:443
  timeout client  50000
  timeout server  50000
  acl exampleDomain hdr(host) -i www.example.com
  use_backend exampleSite if exampleDomain
  default_backend exampleSite
backend exampleSite
  server website 0.0.0.0:85 check
It’s going to depend a little bit on how your docker containers are listening and accessible. If they are locally accessible on port 85 you could try this in your backend section:
127.0.0.1:85
On the machine that is hosting this configuration (and I assume the docker containers) run this;
curl -vvv http://127.0.0.1:85/
That should return a page of some sort. If it doesn’t then this backend configuration won’t work either. Report back with that output if it fails as well as information about how you would normally pull a webpage from your docker instance.
the problem was on my cert files , i generated my cert files and added them to haproxy and every thing worked fine . my fault .
