[Resolved] HAP/Docker/NAS redirecting not proxying
I’ve set up a Haproxy docker container with the latest version 1.7 on my NAS Synology.
The docker configuration seems ok, unless there is some unexpected behavior.
It’s my first time trying to make a Haproxy, I may miss some things.
With my minimalist configuration :
frontend front
		bind *:5036
		use_backend box
backend box
		server box ip_server
When i navigate through “http:/ /ip_Haproxy:5036” i’m redirected to "http:/ /ip_server/"
My trouble is i don’t want my client to be redirected, i want to see the “http:/ /ip_server/” web page through the frontend of Haproxy, with the “http:/ /ip_Haproxy:5036” url in the client browser
According to everything i read, it seemed to me that’s proxying is the basic functionnality of Haproxy, but I don’t even success to do so. Is there something i’m missing ? Is that the configuration or Haproxy simply doesn’t do this ?
Or everything should be ok and it’s more on the end of Docker / DSM i need to look ?
Your backend is redirecting. Maybe you can disable that in your DSM settings?
Otherwise you will probably have to rewrite the Host header, so that DSM doesn’t trigger a redirect.
Toh ! Indeed, when my host header isn’t what it’s defined, my backend redirect 302 to its “good” host… which is a IP address…
That’s sneaky.
Thanks a lot, I’ll practice Haproxy on a backend more friendly ^^
