Hi Team,
I have the following frontend and backend settings in my haproxy configuration file. Even though haproxy redirection to the backend URL it is failing to connect to the backend server.
Error detail :-Unable to connect to Ambari Server. Confirm Ambari Server is running and you can reach Ambari Server from this machine.
frontend main *:80
acl url_dcos path_beg /dcos
acl url_ambari path_beg /ambari
use_backend dcos-backend if url_dcos
use_backend ambari-backend if url_ambari
round robin balancing between the various backends
reqrep ^([^\ ])\ /dcos(/.) \1\ \2
{% for master in groups[‘master-nodes’] %}
server dcos_master{{ loop.index0 }} {{ hostvars[master].ansible_host }}:80 check cookie dcos_master{{ loop.index0 }}
{% endfor %}
reqrep ^([^\ ])\ /ambari(/.) \1\ \2
{% for mgmt in groups[‘management-nodes’] %}
server ambari_server{{ loop.index0 }} {{ hostvars[mgmt].ansible_host }}:8080 check cookie ambari_server{{ loop.index0 }}
{% endfor %}
Please Guide
