Im having an issue with HA Proxy, that its redirecting all traffic to the default backend.
In an previous config, HA Proxy managed to redirect just fine - so the hostname is defined in the TCP package.
Ive tried several different settings, but cant seem to find a solution that works.
Config:
#log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
stats socket /var/run/haproxy.sock mode 600 level admin
stats timeout 2m
maxconn 80000
#option httplog
timeout client 300s
Statistics
bind 192.168.62.148:8040
stats uri /lbstats
stats realm Please\ Login
stats auth admin:admin
stats admin if TRUE
FRONTEND - FRONTEND - FRONTEND - FRONTEND - FRONTEND - FRONTEND - FRONTEND - FRONTEND - FRONTEND
frontend FT_HTTPS_IN
bind 192.168.62.148:443
use_backend BCK_RDS_HTTPS if { req_ssl_sni -i remote .domain .dk }
use_backend BCK_RDS_GW_HTTPS if { req_ssl_sni -i rdsgw .domain .dk }
use_backend BCK_OWNCLOUD_HTTPS if { req_ssl_sni -i oc .domain .dk }
use_backend BCK_POC_WEB if { req_ssl_sni -i poc .domain .dk }
option tcp-smart-accept
default_backend BCK_Exchange_HTTPS
BACKEND - BACKEND - BACKEND - BACKEND - BACKEND - BACKEND - BACKEND - BACKEND - BACKEND - BACKEND
timeout server 300s
server S1EXCH01 192.168.60.82:443 check #ssl verify none
timeout server 300s
server S1TSGW03 192.168.62.90:443 check #ssl verify none
server S1TSGW04 192.168.62.92:443 check #ssl verify none
timeout server 300s
server S1TSWEB01 192.168.62.93:443 check #ssl verify none
timeout server 300s
server S1OC03 192.168.62.100:443 check #ssl verify none
backend BCK_POC_WEB
timeout server 300s
server S1POC01 192.168.62.91:443 check #ssl verify none
HA Proxy Config
The topic is short, since i cant seem to find any misconfigured settings.
PS: the domains are seperated by spaces, since new users can only post 2 links in a topic.
