Convert to HAPROXY configuration
upstream portainer {
server ADDRESS:PORT;
server {
listen 80;
location /portainer/ {
proxy_http_version 1.1;
proxy_set_header Connection “”;
proxy_pass http://portainer/;
location /portainer/ws/ {
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;
proxy_pass http://portainer/ws/;
Please find this link, as I need to serve content with virtual path for the application and the example as with nginx
https://portainer.readthedocs.io/en/stable/faq.html#how-can-i-configure-my-reverse-proxy-to-serve-portainer
Just use the the paragraph below which talks about haproxy. No special configuration is needed.
https://portainer.readthedocs.io/en/stable/faq.html#how-can-i-configure-my-reverse-proxy-to-serve-portainer-using-haproxy
You can replace:
acl portainer hdr_end(host) -i portainer.127.0.0.1.xip.io
use_backend portainer if portainer
With:
defaut_backend portainer
if needed.
On behalf of my colleage ppraj (his posts are spammed, dont know why)
Portainer listens on 192.168.2.57:9000 . Now my HAProxy configured on another machine is has been updated with virtual path
   frontend http-in
    acl has_portainer path_beg /portainer
    use_backend portainer_server if has_portainer
server portainer 192.168.2.57:9000
When I hit /portainer , page come up with BAD REQUEST. The issue is the actual server does not serve with /portainer. Hence I need to strip /portainer and send the request to backend . So I did this
reqrep ^([^\ ]*\ /)portainer[/]?(.*)     \1\2
The page does not load either , but now no BAD REQUEST . Instead I just get blank page , but when I press F12 I can see in the console and the request headers coming up . The URL now in there/css , which is not good as it needs to be 192.168.2.57:9000/css , to make it work .
The links in the page still points to 192.168.2.57:9000 , which is the actual server where it is hosted fails subsequently
Portainer listens on 192.168.2.57:9000 . Now my HAPROxy configured on another machine is has been updated with virtual path
   frontend http-in
Hi, I am newbie and have a query to related to same topic.
NGINX handling for 10080
Hi Umpathy Girirajan,
I found your name in haproxy user list. I am newbie to haproxy and
trying to convert the below nginx config to haproxy.
server {
listen 10080;
listen [::]:10080;
server_name localhost;
    error_page   500 502 503 504  /50x.html;
    location = /50x.html {
        root   html;
#To pass a request to an HTTP proxied server
location / {
proxy_pass http://[::1]:10088;
proxy_set_header Host $host;
proxy_redirect http://[::1] http://$host;
haproxy equivalent:
frontend fe_http_sne_in
bind 0.0.0.0:10080
bind :::10080
default_backend be_sne_insecure
http-request set-header localhost
server srv01 localhost:10088
Is this correct??
Please let me know.
thanks,
