I am trying to change load balancing, which I am using, the main purpose I need this for using Docker Swarm’s DNSRR endpoint mode which nginx cannot resolve.
I’ve such nginx config:
server {
listen 8080;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; # To forward the original client's IP address
proxy_set_header X-Forwarded-Proto $scheme; # to forward the original protocol (HTTP or HTTPS)
proxy_set_header Host $http_host; # to forward the original host requested by the client
proxy_set_header X-Real-IP $remote_addr;
location /swagger/ {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_pass http://swagger-merger/;
location /rabbitmq/ {
proxy_pass http://rabbitmq:15672/;
location /companies/ {
proxy_pass http://companies-api/;
location /links/ {
proxy_pass http://links-api/;
location /news/ {
proxy_pass http://news-api/;
location /importstructure/ {
proxy_pass http://import-structure-api/;
location /structure/ {
proxy_pass http://structure-api/;
location /profile/ {
proxy_pass http://profile-api/;
location /registration/ {
proxy_pass http://registration-api/;
location /files/ {
proxy_pass http://files-api/;
What I need to make the same settings with HAProxy config. What is nginx’s location directive analogue in HAProxy? My HAProxy config:
log fd@2 local2
pidfile /var/run/haproxy.pid
maxconn 4000
stats socket /var/lib/haproxy/stats expose-fd listeners
master-worker
resolvers docker
nameserver dns1 127.0.0.11:53
resolve_retries 3
timeout resolve 1s
timeout retry 1s
hold other 10s
hold refused 10s
hold nx 10s
hold timeout 10s
hold valid 10s
hold obsolete 10s
timeout client 30s
timeout server 30s
backend swagger
option httpchk
retry-on all-retryable-errors
retries 2
server-template swagger-merger- 1 http://swagger-merger check resolvers docker init-addr libc,none
backend stat
stats refresh 15s
stats show-legends
stats show-node
Is that right setup for backend “swagger-merger” which is first in nginx? Or did I miss something? I just need help with one, other I’ll do with analogue.
Thanks in advance for any help!
