HAProxy config issue using docker swarm replica backend
I have a very basic test setup which doesn’t work and I was hoping someone can point me into the right directions
So, for this experiment I use a docker compose file (with Docker Swarm):
version: ‘3.8’
services:
  backend:
    image: nmatsui/hello-world-api
    deploy:
      replicas: 2
    networks:
      - ha_network
    ports:
      - "3000"
  haproxy:
    image: haproxy:latest
    volumes:
      - ./files/haproxy.cfg:/usr/local/etc/haproxy/haproxy.cfg
    ports:
      - "80:80"
    networks:
      - ha_network
networks:
  ha_network:
    driver: overlay
    attachable: true
Now what happens when I start this, I see 2 backends spinning up, but haproxy won’t start complaining about the haproxy.cfg, which in my case is:
    log stdout format raw local0
    maxconn 4096
    timeout client  30s
    timeout server  30s
resolvers docker
    nameserver dns 127.0.0.11:53
    resolve_retries 3
    timeout resolve 1s
    timeout connect 1s
    timeout server 5s
frontend http-in
    default_backend app-backend
backend app-backend
    option httpchk GET /health
    server-template backend 1-10 backend:3000 check resolvers docker
The error is
[NOTICE] (1) : haproxy version is 3.0.5-8e879a5 [NOTICE] (1) : path to executable is /usr/local/sbin/haproxy [ALERT] (1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:20] : ‘timeout’ expects ‘retry’ or ‘resolve’ and as arguments got ‘connect’. [ALERT]
(1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:21] : ‘timeout’ expects ‘retry’ or ‘resolve’ and as arguments got ‘server’. [ALERT] (1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:30]: Missing LF on last line, file might have been truncated at position 69. [ALERT] (1) : config : Error(s) found in configuration file : /usr/local/etc/haproxy/haproxy.cfg [ALERT] (1) : config : Fatal errors found in configuration.
So haproxy doesn’t say what exactly the problem is (I think it is in the last line). Any suggestions what the problem might be or how to debug this and where I can find more details about connecting HaProxy with replicas?
Haproxy says relative exactly, what the problem is:
[ALERT] (1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:21] : ‘timeout’ expects ‘retry’ or ‘resolve’ and as arguments got ‘server’.
So, Line 20,21 and 30 in your config are the problem.
It also says, that timeout in Line 20 and 21 is only possible with “retry” or “resolve”. So, “timeout connect” and “timeout server” are wrong at this place.
At Line 30, set the LineFeed new :wink:
Compare the documentation: HAProxy Enterprise Documentation version 2.9r1 (1.0.0-329.562) - Configuration Manual
best regards,
Markus
