I have the following nginx config that works perfectly fine and I need to convert it to haproxy config:
map $sent_http_content_type $expires {
default off;
text/html epoch;
text/css max;
application/javascript max;
~image/ max;
upstream app {
server localhost:5000;
upstream websocket {
server {
listen 80 default_server;
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
ssl_certificate /etc/nginx/ssl/domain.com/2018/ssl-bundle.crt;
ssl_certificate_key /etc/nginx/ssl/domain.com/2018/domain.key;
ssl_dhparam /etc/nginx/ssl/domain.com/dhparam.pem;
ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
ssl_ecdh_curve secp384r1;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
ssl_session_cache shared:TLS:2m;
ssl_stapling on;
ssl_stapling_verify on;
server_name domain.com;
root /home/deploy/rails/appUI/current/public/;
try_files $uri/index.html $uri @app;
expires $expires;
location /cable {
proxy_pass http://websocket;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection Upgrade;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-Proto https;
proxy_redirect off;
location @app {
proxy_pass http://app;
client_max_body_size 4G;
As you can see there is the application (app) and a websocket both running on the same port. The above works perfectly fine in nginx. I have tried to build an haproxy config but the app breaks as follows:
log 127.0.0.1 local1 notice
maxconn 2000
spread-checks 5
stats socket /var/run/haproxy.sock mode 0600 level admin
ssl-default-bind-ciphers AES128+EECDH:AES128+EDH
ssl-default-bind-options no-sslv3 no-tls-tickets force-tlsv12
defaults http_proxies
timeout http-request 5s
option allbackups
option log-separate-errors
cookie SERVERID insert nocache
maxconn 20000
timeout client 1150s
timeout server 1180s
default-server inter 15s fastinter 10s downinter 20s
frontend HTTP
redirect scheme https code 301 if { hdr(Host) -i domain.com } !{ ssl_fc }
default_backend webservers
frontend HTTPS
bind *:443 ssl crt /etc/nginx/ssl/domain.com/2018/domain.pem
http-response set-header Cache-Control no-cache,\ max-age=0
acl is_websocket hdr(Upgrade) -i WebSocket
acl is_websocket_server hdr_end(host) -i domain.com
use_backend websock if is_websocket is_websocket_server
backend webservers
timeout server 30s
option httpchk HEAD / HTTP/1.1\r\nHost:\ domain.com
server server1 10.131.74.88:5000 check
backend websock
timeout server 30s
With the haproxy config it looks like ‘broken CSS’. Could anyone pls help me.
Regards
