CRL list problem
Hi, I have installed haproxy 1.8.7 and get problem with CRL list - even when I revoke a user’s certificate, the page appears to him.
test1 is my test user
  1. CERT REVOKE:
    openssl ca -config /root/ca/intermediate/openssl.cnf -revoke /root/ca/users_certs/test1/test1.crt
  2. REGENERATE CRL
    openssl ca -config /root/ca/intermediate/openssl.cnf -gencrl -out /root/ca/intermediate/crl/intermediate.crl
  3. ORDER CERT CHAIN IN HAPROXY CONFIG FILE (ca_chain.crt)
    — INTERMEDIATE CERT —
    — CA CERT —
  4. ORDER CRL CHAIN IN HAPORXY CONFIG FILE (crl.pem)
    — INTERMEDIATE CRL —
    — CA CRL —
  5. ORDER FILES IN my.page.pem FILE
    — PRIVATE KEY WITHOUT PASSWORD —
    — my.page CERT SIGNED BY INTERMEDIATE CERT —
  6. Full /etc/haproxy/haproxy.cfg
             maxconn 2048
             log     global
             mode    http
             option  httplog
             option  dontlognull
             timeout client  50000
             timeout server  50000
             stats uri /stats
             stats auth user:password
     frontend www-http_my-page
             bind 192.168.0.211:80
             default_backend www-backend_my-page
     frontend www-https_my-page
             bind 192.168.0.211:443 transparent ssl crt /etc/ssl/private/my.page.pem ca-file /etc/haproxy/cert/ca_chain.crt verify required crt-ignore-err all crl-file /etc/haproxy/cert/crl.pem
             server web1 192.168.0.212:80 check cookie web1
             server web2 192.168.0.213:80 check cookie web2
Are you sure you are reloading haproxy after updating the CRL? Also I suggest you remove the option crt-ignore-err all entirely.
@lukastribus thanks for your reply. When I removed crt-ignore-err all and restart haproxy all works well.
THANK YOU!
