It seems that the CRL publishing is not the problem, at least not only this one. When I try to connect to the service HAProxy asks for the certificate and then the connection fails with google chrome error “ERR_BAD_SSL_CLIENT_AUH_CERT”
I don’t know where the error is, and what exactly produces it. If I restart the HAProxy service it works again.
Part of my config is:
log 127.0.0.1 local0 notice
# Tune SSL
frontend http_frontend
bind 10.0.0.233:80
frontend https_frontend
bind 10.0.0.233:443 ssl crt /etc/haproxy/certs/xxx.pem ca-file /etc/ssl/certs/ca.pem verify required crt-ignore-err all crl-file /mnt/CRL/crl.pem
use_backend errors unless { ssl_c_verify 0 }
default_backend nc_demo_web_servers
backend errors
redirect location http://xxxxx/errors/errorcertrevoked.html if { ssl_c_verify 23 }
redirect location http://xxxxx/errors/errorcertexpired.html if { ssl_c_verify 10 }
stick-table type ip size 200k expire 30m
stick on src
server srv1 10.0.1.211:80 check
$ haproxy -vv
HA-Proxy version 1.6.3 2015/12/25
Copyright 2000-2015 Willy Tarreau
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2g-fips 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
This output is displayed when HAProxy is working right.
No, ca-ignore-err is not set, crt-ignore-err is set. There’s a difference.
Completely aware that the entire point here is to check CRL’s, but in troubleshooting we need to track the issue down to a specific feature and code path, to be able to do anything about that.
By the way: a CRL has a very limited lifetime, usually something like 24 hours. Are you sure haproxy is often enough reloaded with a uptodate CRL so that the CRL haproxy uses does not expire? That’s would have exactly the effect you are describing here.
In order for the error to comes up quickly I have published the CRL every 2 hours. Let me do some changes and investigation and I’ll keep you informed.
I have read in some forums that HAProxy needs to be restarted/reloaded everytime the CRL file is changed because it loads at the time it’s started and does not look for changes.
If this is the normal behavior my problem is that, I think, is it that way?
Yes, the CRL file is only read when haproxy is started. When you update the CRL file, you need to reload haproxy as well, otherwise the changes will never be applied and the CRL file will expire.
