I have a problem – I want to terminate SSL at haproxy and load balance a bunch of servers based on JSESSIONID and SNI. It is almost working, but fails exactly at what I need to do.
My config is this:
---------------CONFIG-------------
debug
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE$
timeout client 120m
Bind front-end address and add SNI logic to separate regions
frontend www-unsecured
http-request redirect scheme https
use_backend http-hq-servers if { hdr(host) -i jde-hq-h.domain.com }
use_backend http-ru-servers if { hdr(host) -i jde-ru-h.domain.com }
frontend www-secured
bind *:443 ssl crt /etc/ssl/certs/ekg/wild.domain.com.pem
log /dev/log local2 debug
use_backend http-hq-servers if { ssl_fc_sni -i jde-hq-h.domain.com }
use_backend http-ru-servers if { ssl_fc_sni -i jde-ru-h.domain.com }
stick-table type string len 74 size 200k expire 120m
stick store-response res.cook(JSESSIONID)
stick match req.cook(JSESSIONID)
server web-hq-1-port-11501.domain.com 10.11.2.11:11501 check maxconn 50
server web-hq-1-port-11601.domain.com 10.11.2.11:11601 check maxconn 50
Now what happens is that http–>https redirect works fine, and I get a nice front page of web server.
Stickiness within SNI group also works – I can see that JSESSIONID is in the sticky table.
But when I log into webserver, the next request back from web server goes to http (80) port.
as can be seen in log:
Nov 6 13:51:56 jde-load-html haproxy[4911]: 10.11.99.111:51334 [06/Nov/2019:13:51:56.735] www-secured~ http-hq-servers/web-hq-1-port-11501.domain.com 0/0/10 1997 – 7/6/0/0/0 0/0
Nov 6 13:52:12 jde-load-html haproxy[4911]: 10.11.99.111:51333 [06/Nov/2019:13:52:12.443] www-unsecured www-unsecured/ 0/-1/-1/-1/0 301 137 - - LR-- 8/2/0/0/0 0/0 “POST /jde/E1Menu.maf HTTP/1.1”
Nov 6 13:52:12 jde-load-html haproxy[4911]: 10.11.99.111:51337 [06/Nov/2019:13:51:56.745] www-secured~ http-hq-servers/web-hq-1-port-11501.domain.com 0/0/15722 7899 – 7/6/5/0/0 0/0
and I get redirected back to the first page.
When I disable this line [http-request redirect scheme https] (redirect to https at http port) in the www-unsecured frontend, then SNI switching works, sticky table works with http. From https I correctly get the front page, then I get bounced back to http, but instead of loop it works and stays in http.
How can I correctly terminate ssl and get this to work? The documentation also does not help, all the examples are similar, but just does not work for me. What am I doing wrong?
