Cross-Origin Request Blocked:
First, heres the haproxy -vv:
HA-Proxy version 1.8.8-1ubuntu0.10 2020/04/03
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-RAYurj/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
So I use HAproxy to access LXD containers. I installed the lua.cors directives into the haproxy.cfg but I am still getting the COR request blocked?
mydomain .us is ficticious as I don’t want traffic on my site right now.
website is an LXD container, accessed with http or https://www.mydomain.us. The acl for website works fine with or without the cors.lua.
The problem is broadcast is an LXD container running Ubuntu 18.04 and a nodejs app running on port 9001 and accessed with https://bcast.mydomain.us I can get to the webpage, but it is producing the Cross-Origin Request Blocked and I cannot proceed from the page. Here is the error:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://localhost:9001/socket.io/?userid=1o1hbuzwazgacognu4f…imitPerUser=1&extra=%7B%7D&EIO=3&transport=polling&t=N8yWFI-. (Reason: CORS request did not succeed)
I inserted cors.lua. but it seems the error is beyond haproxy?
I tried the “*” in the http-response but it did not help.
Here is my haproxy.cfg:
`global
log 127.0.0.1 local0 notice info
lua-load /etc/haproxy/cors.lua
maxconn 2000
tune.maxrewrite 4096
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM
timeout client 5000
timeout server 5000
timeout tunnel 2h #this is for websocket connections, 2 hours inactivity timeout
timeout client-fin 5000
frontend http_lb
http-request lua.cors
http-response lua.cors “GET,PUT,POST” “bcast.mydomain.us”
bind *:8888
Test URI to see if its a letsencrypt request
bind *:443 ssl crt /etc/haproxy/certs
acl website hdr(host) -i mydomain.us www.mydomain.us
acl broadcast hdr(host) -i bcast.mydomain.us
use_backend mainweb if website
use_backend bcast1 if broadcast
backend mainweb
http-request set-header X-Client-IP %[src]
redirect scheme https if ! { ssl_fc }
server website website.lxd:80 check
backend bcast1
server broadcast1 broadcast.lxd:9001 check ssl verify none
I appreciate any comments or suggestions for fixing this. I will be glad to provide any additional information you may need.
Ray
