Haproxy1.6.8 crash
who can resolve this problem ?
00000004:lua.clihdr[000b:000c]: If-Modified-Since: Wed, 03 Aug 2016 10:05:28 GMT
haproxy: malloc.c:2842: mremap_chunk: Assertion `((size + offset) & (_rtld_global_ro._dl_pagesize - 1)) == 0’ failed.
sudo haproxy -vv
HA-Proxy version 1.6.8 2016/08/14
TARGET = linux26
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_LINUX_SPLICE=1 USE_LINUX_TPROXY=1 USE_CRYPT_H=1 USE_ZLIB=1 USE_VSYSCALL=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_STATIC_PCRE=1 USE_PCRE_JIT=1 USE_TFO=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Running on OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Built with PCRE version : 8.31 2012-07-06
PCRE library supports JIT : no (libpcre build without JIT?)
Built with network namespace support
Please share the configuration and some specifics about the crash (when does it crash? how does it crash? under load, or when a specific request comes in?).
Can you reliably reproduce the crash?
Please provide a backtrace, preferably without compiler optimizations:
  1. compile with CFLAGS="-O0 -g -fno-strict-aliasing -Wdeclaration-after-statement"
  2. enable coredumping: ulimit -c unlimited (before starting haproxy)
  3. reproduce the crash
  4. use gdb to provide a backtrace (“gdb haproxy core” and “bt full” in the gdb cli)
Please report those findings to the mailing list at haproxy at formilux dot org (no need to subscribe).
Thanks!
