Built with OpenSSL version : OpenSSL 1.0.1k-fips 8 Jan 2015
Running on OpenSSL version : OpenSSL 1.0.1k-fips 8 Jan 2015
Built with PCRE version : 8.21 2011-12-12
Running on PCRE version : 8.21 2011-12-12
It’s really strange. This bug was already reported and fixed on the mailing-list. So it should be ok. And if not, it should definitely not break everything.
Sorry to ask, but are you sure your build is correct ?
Try elaborating about more though. It’s pretty much impossible for anyone to analyze the the root cause if all the information you give us is “it doesn’t work at all, the stats page doesn’t even open”.
What’s the log output? What’s the CPU load? What’s the exact snapshot release you used (provide haproxy -vv)?
Almost no CPU load and 61k tcp connections in CLOSE_WAIT State
