My Haproxy 1.7.9 instance is using 100% of cpu core - for 10-50min, then all goes to normal.
Couple of mbit/s of traffic.
haproxy -vvv
HA-Proxy version 1.7.9 2017/08/18
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CPU = native
CC = gcc
CFLAGS = -O2 -march=native -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_STATIC_PCRE=1 USE_TFO=1
Built with OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
Running on PCRE version : 8.38 2015-11-23
Built without Lua support
Runnig on Ubuntu 16.04
Trace from haproxy process consuming whole core:
https://pilv.laevakompanii.ee/s/R8sYfgYNpVjbwdQ
No errors in debug log.
