I’m making some tests with HAProxy to do SSL offloading in Centos 7. I’ve seen that the cpu easily reach 100% and the haproxy idle pct is almost 0%. The test is just a 1000 clients connections.
I’ve also done the same tests in ubuntu 16 to compare and the results are better by far.
This is the info of every platform for the tests:
HAproxy configuration (same for both)
pidfile /var/run/haproxy.pid
maxconn 20000
cpu-map 1 0
ssl-default-server-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 4s
timeout check 10s
frontend http
bind :80
maxconn 20000
default_backend back1
frontend https
bind :443 ssl crt /etc/ssl/test.pem
maxconn 20000
backend back1
balance source
timeout check 3s
http-check expect rstatus 200
stick-table type ip size 10k
stick on src
server app1 x.x.x.x:80 weight 1 check inter 10s fall 3 maxconn 1000
centos 7 - haproxy 1.7.5 - openssl-1.0.1e-fips
#haproxy -vv
HA-Proxy version 1.7.5 2017/04/03
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
ubuntu 16 - haproxy 1.6.3 - openssl-1.0.2g
#haproxy -vv
HA-Proxy version 1.6.3 2015/12/25
Copyright 2000-2015 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2g-fips 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
Graphs - CPU Usage - Idle PCT - 1000 concurrent clients
CentOS 7
Ubuntu 16
The same tests repeated through HTTP offer equal results in the same platform. So it seems something related to the openssl library.
Digging into the syscalls; I’ve created some flame graphs to see what happen under the hood:
As you can see, there is the bn_mul_mont function that is in the CPU for a long time in CentOS 7.
Can anyone clarify why in CentOS 7 the use of the CPU is so high? Could be because the openssl library in CentOS 7 uses the FIPS encryption? Does anyone suffer the same behaviour?
Thanks for you help,
David
