HAProxy SSL Offloading high CPU usage on CentOS 7
I’m making some tests with HAProxy to do SSL offloading in Centos 7. I’ve seen that the cpu easily reach 100% and the haproxy idle pct is almost 0%. The test is just a 1000 clients connections.
I’ve also done the same tests in ubuntu 16 to compare and the results are better by far.
This is the info of every platform for the tests:
HAproxy configuration (same for both)
    chroot      /var/lib/haproxy
    maxconn     20000
    user        haproxy
    group       haproxy
    tune.ssl.default-dh-param   2048
    cpu-map                     1 0
    ssl-default-server-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
    mode                    http
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         5s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 4s
    timeout check           10s
frontend http
    bind    :80
    mode    http
    maxconn 20000
    default_backend back1
frontend https
    bind    :443 ssl crt /etc/ssl/test.pem
    mode    http
    maxconn 20000
backend back1
    balance source
    mode    http
    option  forwardfor
    timeout check 3s
    http-check expect rstatus 200
    stick-table type ip size 10k
    stick on src
    server app1 x.x.x.x:80 weight 1 check inter 10s fall 3 maxconn 1000
centos 7 - haproxy 1.7.5 - openssl-1.0.1e-fips
#haproxy -vv
HA-Proxy version 1.7.5 2017/04/03
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
  OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
ubuntu 16 - haproxy 1.6.3 - openssl-1.0.2g
#haproxy -vv
HA-Proxy version 1.6.3 2015/12/25
Copyright 2000-2015 Willy Tarreau <willy@haproxy.org>
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
  OPTIONS = USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2g-fips  1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g  1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
Graphs - CPU Usage - Idle PCT - 1000 concurrent clients
CentOS 7
Ubuntu 16
The same tests repeated through HTTP offer equal results in the same platform. So it seems something related to the openssl library.
Digging into the syscalls; I’ve created some flame graphs to see what happen under the hood:
CentOS 7
http://svgshare.com/s/1ve
Ubuntu 16
http://svgshare.com/s/1vm
As you can see, there is the bn_mul_mont function that is in the CPU for a long time in CentOS 7.
Can anyone clarify why in CentOS 7 the use of the CPU is so high? Could be because the openssl library in CentOS 7 uses the FIPS encryption? Does anyone suffer the same behaviour?
Thanks for you help,
David
P.S: Sorry for the external images link but discouse cannot allow me to upload more than one (new users restriction)
