Hi !
I’ve been trying to load 100.000 distinct SSL certificates with HAProxy v1.8.13, to no avail.
My test server is a virtual machine with 4 vCPU and 8GB of RAM.
Here’s my configuration so far :
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
stats maxconn 10
crt-base /etc/ssl/haproxy
ssl-default-bind-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
ssl-default-server-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
maxconn 100000
spread-checks 4
nbthread 4
maxconn 100000
timeout client 60s
timeout server 60s
timeout queue 60s
timeout connect 4s
timeout http-request 5s
option httpclose
option abortonclose
option httpchk GET / HTTP/1.0\r\nUser-agent:\ haproxy-httpchk
retries 2
frontend ft_frontend
bind 127.0.0.1:80
bind ::1:80
acl servers_down nbsrv(bk_backend) lt 1
monitor-uri /ping
monitor fail if servers_down
default_backend bk_backend
frontend ft_frontends
bind 127.0.0.1:443 ssl crt /etc/ssl/haproxy
bind ::1:443 ssl crt /etc/ssl/haproxy
monitor-uri /ping
backend bk_backend
server www1 10.0.0.1:8080 check inter 5s maxconn 25000
server www2 10.0.0.1:8081 check inter 5s maxconn 25000
server www3 10.0.0.2:8080 check inter 5s maxconn 25000
server www4 10.0.0.2:8081 check inter 5s maxconn 25000
I’ve generated 100.000 self-signed SSL certificates using EasyRSA (2048 bits RSA), all of them stored in the /etc/ssl/haproxy folder.
Here are the result I am seeing when I reload HAProxy :
- with 10.000 certificates
time service haproxy reload
[ ok ] Reloading haproxy: haproxy.
service haproxy reload 49,56s user 6,02s system 97% cpu 56,987 total
- with 20.000 certificates
service haproxy reload 94,24s user 9,59s system 99% cpu 1:44,11 total
- with 30.000 certificates
service haproxy reload 143,05s user 14,41s system 99% cpu 2:37,94 total
- with 40.000 certificates
service haproxy reload 190,40s user 23,97s system 96% cpu 3:41,17 total
- with 50.000 certificates
The process gets killed with an out of memory error.
The reload process seems to be pretty CPU heavy (100% usage during the whole reload process), but to only use one of the available vCPUs.
It would also seem HAProxy takes 5 more seconds to reload per 1.000 certificates I add. Is there any way to speed up the reload process ? I have not found anything regarding this in the documentation.
I’m also suprised to get an out of memory issue while loading ~400MB certificates. Am I missing something obvious ?
I also had a benchmark running during the reloads (1000 request per seconds towards the HAProxy internal monitoring URL I configured on /ping). No requests were lost during any of my tests, which is quite impressive !
Any help or tips would be appreciated !
Thanks !
