Haproxy, SSL Pass-through, with 5 Apache Virtual Hosts on Ubuntu 22.04
Hello, can anyone point me to a good configuration example for my current setup?
One Haproxy device with SSL Pass-through to 5 Apache Virtual Hosts on 2 Ubuntu 22.04 servers. Below is the config I have so far and it is not working:
stats socket *:1999 level admin
stats socket /var/run/haproxy.sock mode 600 level admin
server-state-file /etc/haproxy/haproxy.state
default-server init-addr none
frontend https
bind *:443
default_backend backend_servers
resolvers mydns
nameserver dns1 10.10.10.100:53
parse-resolv-conf
resolve_retries 3
timeout resolve 1s
timeout retry 1s
hold other 30s
hold refused 30s
hold nx 30s
hold timeout 30s
hold valid 10s
hold obsolete 30s
option log-health-checks
option ssl-hello-chk
server mirage 10.10.10.105:443
server wynn 10.10.10.106:443
bind :8800
stats uri /
stats hide-version
stats auth :**
default_backend servers
bind :8085
stats uri /stats
stats realm HAProxy-04\ Statistics
stats auth admin:
stats admin if TRUE
