Haproxy ssl issue
I have centos 7 with haproxy installed (HA-Proxy version 1.5.18 2016/05/10).
I have a Windows server with IIS contains a web site.
Eevery thing work perfectly without ssl if i try to add secure connexion with sectigo SSL the web site will not work.
bellow my configuration file haproxy.cfg:
log /dev/log local0 debug
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend web-servers
bind 10.5.120.61:80
#bind 10.5.120.61:443 ssl crt /etc/ssl/certs/myssl.pem
#redirect scheme https code 301 if !{ ssl_fc }
#mode http
default_backend web-servers
backend web-servers
cookie JSESSIONID prefix
option httpclose
server app 10.5.120.60:81 cookie app
listen stats 10.5.120.61:7071
stats uri /stats
stats hide-version
stats show-node
stats auth admin:123
Haproxy 1.5.8 is “very” old and since october 2020 not longer maintained. also centos 7 is “old”.
have you enabled tlsv1.1 and tlsv1.2? what error do you get? have you tried to connect with openssl s_client
i wouuld suggest to upgrade to a newer version of haproxy. maybe complile the latest version.
maybe it is a combination of old haproxy, old openssl etc.
Done, but nothing changed same issue still exist
