Apache Creating Non HTTPS Link When Using SSL Termination
HAProxy noob here! Setup has been straight forward so far, but I have one issue I can not seem to solve. I am using SSL Termination with HAProxy and have that working. But, the Apache backends are creating non HTTPS links when serving pages, causing browsers to note something is up. I have thrown the sink at it so far, with no luck. Version is: HA-Proxy version 1.8.13-1ppa1~bionic 2018/08/01
Current config file:
ssl-server-verify none
frontend www-http
bind *:443 ssl crt /etc/ssl/haproxy/XXXXXXX.pem
    http-request set-header X-SSL %[ssl_fc]
    http-response add-header Strict-Transport-Security max-age=31536000
    # Test URI to see if its a letsencrypt request
    default_backend apache
backend apache
option httpclose
    server web1 cluster2-web-01:80
    server web2 cluster2-web-02:80
bind :32700
stats uri /
stats hide-version
stats auth XXX:XXX
All you can do is to set the X-Forwarded-Proto header, which you already do. If the backend still ignores it, you probably need to set some flag in the backend application configuration.
There is not much you can do at haproxy layer though.
I finally figured this out, in the case someone else is suffering from the same issue. The apps that sit on the backend are written in the Laravel PHP framework. I had to configure trusted proxies within the Laravel config and that fixed the issue.
https://laravel.com/docs/5.7/requests#configuring-trusted-proxies
