Problem:
Iam trying to build a forward proxy with ssl termination, further it upstreams to my proxy servers eg: TOR. My upstream proxy services are non-https.
Client → Network-Haproxy → Uptstream-Proxy → Internet
I could easily succeed in tcp mode of HAproxy without ssl termination, but when I terminate ssl and forward, things don’t work.
Steps Followed:
I followed the below steps to generate self-certified ssl certificates.
$ openssl req -new -newkey rsa:2048 -sha256 -days 365 -nodes -x509 -extensions v3_ca -keyout haproxy-ca-key.pem -out haproxy-ca-cert.pem -subj "/C=GB/ST=London/L=London/O=Global Security/OU=IT Department/CN=example.com"
combined them for creating final .pem file
$ cat haproxy-ca-cert.pem haproxy-ca-key.pem >> mysite.pem
The above file is used in my haproxy.cfg for ssl termination.
ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256::RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
stats uri /stats
stats auth user:password
frontend www.mysite.com
bind 0.0.0.0:8443
bind 0.0.0.0:443 ssl crt /home/ubuntu/haproxy/mysite.pem crt-ignore-err all
default_backend web_servers
backend web_servers
server server1 xx.xx.xx.xx:xxxx #my upstream server which is not ssl protected
When I try to curl from my client machine to use the above proxy I get following error.
$ curl -k --proxy https://my-haproxy-server:443 --cacert haproxy-ca-cert.pem https://httpbin.org/ip -vvv
* Trying my-haproxy-server...
* TCP_NODELAY set
* Connected to my-haproxy-server (my-haproxy-server) port 443 (#0)
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS Unknown, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Unknown (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (OUT), TLS alert, Server hello (2):
* SSL certificate problem: self signed certificate
* Closing connection 0
curl: (60) SSL certificate problem: self signed certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
If you have read the cfg file, you can see I have redirected :8443 to :443, so I can send request to non https proxy, but that too doesn’t work
$ curl -k --proxy http://my-haproxy-server:8443 --cacert haproxy-ca-cert.pem https://httpbin.org/ip -vvv
* TCP_NODELAY set
* Connected to my-haproxy-server (my-haproxy-server) port 8443 (#0)
* allocate connect buffer!
* Establish HTTP proxy tunnel to httpbin.org:443
> CONNECT httpbin.org:443 HTTP/1.1
> Host: httpbin.org:443
> User-Agent: curl/7.58.0
> Proxy-Connection: Keep-Alive
< HTTP/1.1 302 Found
< content-length: 0
< location: https://httpbin.org:443/
< cache-control: no-cache
< connection: close
* Received HTTP code 302 from proxy after CONNECT
* CONNECT phase completed!
curl: (56) Received HTTP code 302 from proxy after CONNECT
Any lead would be appreciated.
Extra Info:
- HAPROXY: HA-Proxy version 2.0.13-1ppa1~bionic 2020/02/15 - https://haproxy.org/
- OPENSSL: OpenSSL 1.1.1 11 Sep 2018
- CURL: curl 7.58.0 (x86_64-pc-linux-gnu) libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
- SF post: https://serverfault.com/questions/1005257/haproxy-forward-proxy-with-ssl-termination
