<NOSRV> issue with TLS termination
Hi everybody,
I got an issue with HAProxy with SSL/TLS termination.
When I do a HTTPS request, I got the following error :
Oct 16 10:39:28 localhost haproxy[724]: xxx.xxx.xxx.xxx:62597 [16/Oct/2020:16 10:39:28.658] w-https~ w-backend/<NOSRV> -1/-1/-1/-1/0 400 188 - - PR-- 2/2/0/0/3 0/0 "GET / HTTP/1.1"
HAProxy blocks the request (PR), but I don’t why .
Can you help me ?
This is my haproxy.cfg :
        log /dev/log    local0
        log /dev/log    local1 notice
        log     global
        mode    http
        option  httplog
        option  dontlognull
        option http_proxy
        timeout client  50000
        timeout server  5000
frontend w-http
        default_backend w-backend
        # le request
        acl le-acl path_beg /.well-known/acme-challenge/
        use_backend le-backend if letsencrypt-acl
frontend w-https
        bind *:8000-9000 ssl crt /etc/haproxy/certs/www.example.com.pem
        bind *:443 ssl crt /etc/haproxy/certs/www.example.com.pem
backend w-backend
        server w1 aaa.aaa.aaa.aaa check port 80
        server w2 bbb.bbb.bbb.bbb check port 80
backend le-backend
        server le 127.0.0.1:54321
As per:
The PR error code means
The proxy blocked the client's HTTP request, either because of an
invalid HTTP syntax, in which case it returned an HTTP 400 error to
the client, or because a deny filter matched, in which case it
returned an HTTP 403 error.
Since you see 400, it means the HTTP request is invalid.
If you are sure about the client and want to investigate further on haproxy, use the show errors command on the admin socket.
When I run : sudo echo "show errors" | sudo socat unix-connect:/run/haproxy/admin.sock stdio , I got this result : Total events captured on [19/Oct/2020:10:51:34.759] : 0
Could you help me ?
Also, I ran : haproxy -vv to give more informations about my haproxy
HA-Proxy version 1.8.19-1+deb10u3 2020/08/01
Copyright 2000-2019 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-OkbS59/haproxy-1.8.19=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-null-dereference -Wno-unused-label
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Running on OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Built with PCRE2 version : 10.32 2018-09-10
Can you provide the output of a curl -vv https://destination call? Is this happening with 100% of the HTTPS requests?
Are you sure the modified configuration provided corresponds with what you are running here?
Are you accessing port 443 or one of those high ports 8000-9000 ?
Yes, I can do it , this is the result : (curl -vv https://www.example.com )
* Expire in 0 ms for 6 (transfer 0x7fffbb5cff50)
* Expire in 1 ms for 1 (transfer 0x7fffbb5cff50)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Expire in 1 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 2 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 4 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 3 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 8 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 6 ms for 1 (transfer 0x7fffbb5cff50)
* Expire in 9 ms for 1 (transfer 0x7fffbb5cff50)
*   Trying 78.222.220.190...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x7fffbb5cff50)
* Connected to www.example.com (78.222.220.190) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: none
  CApath: /etc/ssl/certs
} [5 bytes data]
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.3 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
{ [19 bytes data]
* TLSv1.3 (IN), TLS handshake, Certificate (11):
{ [2816 bytes data]
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
{ [520 bytes data]
* TLSv1.3 (IN), TLS handshake, Finished (20):
{ [52 bytes data]
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
* TLSv1.3 (OUT), TLS handshake, Finished (20):
} [52 bytes data]
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use h2
* Server certificate:
*  subject: CN=www.example.com
*  start date: Oct 16 13:36:07 2020 GMT
*  expire date: Jan 14 13:36:07 2021 GMT
*  subjectAltName: host "www.example.com" matched cert's "www.example.com"
*  issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
*  SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
} [5 bytes data]
* Using Stream ID: 1 (easy handle 0x7fffbb5cff50)
} [5 bytes data]
> GET / HTTP/2
> Host: www.example.com
> User-Agent: curl/7.64.0
> Accept: */*
{ [5 bytes data]
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
{ [57 bytes data]
{ [57 bytes data]
* old SSL session ID is stale, removing
{ [5 bytes data]
* Connection state changed (MAX_CONCURRENT_STREAMS == 100)!
} [5 bytes data]
< HTTP/2 400
< cache-control: no-cache
< content-type: text/html
{ [90 bytes data]
100    90    0    90    0     0    967      0 --:--:-- --:--:-- --:--:--   978
* Connection #0 to host www.example.com left intact
I kept looking, and yes, I changed the configuration, but the result is the same.
All my https requests on port 443 or in the range 8000-9000 give me the same result : 400 Bad request.
This my haproxy.cgf at this point :
        log /dev/log    local0
        log /dev/log    local1 debug
        #stats socket /var/run/haproxy.sock mode 660 level admin expose-fd listeners
        stats timeout 5s
        # generated 2020-10-19, Mozilla Guideline v5.6, HAProxy 1.8.19, OpenSSL 1.1.1d, modern configuration, no HSTS
        # https://ssl-config.mozilla.org/#server=haproxy&version=1.8.19&config=modern&openssl=1.1.1d&hsts=false&guideline=5.6
        # modern configuration
        ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tlsv12 no-tls-tickets
        ssl-default-server-options no-sslv3 no-tlsv10 no-tlsv11 no-tlsv12 no-tls-tickets
        log     global
        mode    http
        option  httplog
        option  dontlognull
        option http_proxy
        timeout server  5000
        stats hide-version
        stats refresh 5s
        stats uri /hastats
frontend w-http
        # Test URI to see if its a le request
        use_backend le-backend if le-acl
frontend w-https
        option http_proxy
        bind *:8000-9000 ssl crt /etc/haproxy/certs/radio4.lips.ovh.pem
        bind *:443 ssl crt /etc/haproxy/certs/radio4.lips.ovh.pem alpn h2,http/1.1
        http-request set-header X-Real-IP %[src]
        #http-request add-header X-Forwarded-Proto https
        #http-request add-header X-Forwarded-Port 443
        # set HTTP Strict Transport Security (HTST) header
        http-response add-header Strict-Transport-Security max-age=15768000
backend w-backend
        server web1 192.168.56.101:80 check
        server web2 192.168.56.102:80 check
backend le-backend
        server le 127.0.0.1:8080
option http_proxy is wrong, you need to remove it from the entire configuration.
I also suggest you remove option http-server-close everywhere, it makes no real sense.
Yes, you’re right.
I cleaned up my haproxy.cfg, but the result it’s the same.
        log /dev/log    local0
        stats timeout 5s
        log     global
        mode    http
        option  httplog
        option  dontlognull
        option http_proxy
        timeout server  5000
        stats hide-version
        stats refresh 5s
        stats uri /hastats
frontend w-http
frontend w-https
        option http_proxy
        bind *:443 ssl crt /etc/haproxy/certs/www.example.com.pem alpn h2,http/1.1
backend w-backend
backend le-backend
And in the logs /var/logs/haproxy.log , I got this :
Oct 21 18:57:18 cmash haproxy[487]: 192.168.1.254:64312 [21/Oct/2020:18:57:18.335] w-https~ w-backend/ -1/-1/-1/-1/0 400 187 - - PR-- 1/1/0/0/3 0/0 “GET /favicon.ico HTTP/1.1”
To set up my haproxy , I followed this tutorial :
https://www.digitalocean.com/community/tutorials/how-to-secure-haproxy-with-let-s-encrypt-on-ubuntu-14-04
I just found the mistake. The trouble was from the option proxy in the default’s section.
Thank you @lukastribus for your time and your help.
