Hi there!
We use Haproxy v2.2 (upgraded from 1.8) to load balance traffic to our web server stack of a few debian based vps servers, hosting a php website with apache2 (mpm_event) and php-fpm.
Ever since activating h2 on the haproxy config for the frontend part
frontend ws-443-in
bind 172.16.xx.xxx:443 ssl crt certfile-path alpn h2,http/1.1
default_backend ws-443
backend ws-443
option httpchk
timeout check 1000
server ws1 ws1.domain.net:443 weight 2 check ssl verify none
server ws2 ws2.domain.net:443 weight 2 check ssl verify none
server ws3 ws3.domain.net:443 weight 2 check ssl verify none
server ws4 ws4.domain.net:443 weight 2 check ssl verify none
server ws5 ws5.domain.net:443 weight 2 check ssl verify none
server ws6 ws6.domain.net:443 weight 2 check ssl verify none
the haproxy log gets spammed with bad requests like the following:
Jun 22 12:19:09 haproxy3 haproxy[20432]: 37.72.xx.xxx:53049 [22/Jun/2021:12:19:09.875] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 365/297/0/0/0 0/0 "<BADREQ>"
Jun 22 12:19:13 haproxy3 haproxy[20432]: 92.137.xx.xxx:56220 [22/Jun/2021:12:19:13.661] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 371/302/0/0/0 0/0 "<BADREQ>"
Jun 22 12:19:29 haproxy3 haproxy[20432]: 84.190.xx.xxx:56796 [22/Jun/2021:12:19:29.723] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 381/306/0/0/0 0/0 "<BADREQ>"
Jun 22 12:19:35 haproxy3 haproxy[20432]: 178.51.xx.xxx:24415 [22/Jun/2021:12:19:35.957] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 378/302/0/0/0 0/0 "<BADREQ>"
Jun 22 12:19:39 haproxy3 haproxy[20432]: 95.91.xx.xxx:61266 [22/Jun/2021:12:19:39.545] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 371/292/0/0/0 0/0 "<BADREQ>"
Jun 22 12:19:41 haproxy3 haproxy[20432]: 217.136.xx.xxx:37964 [22/Jun/2021:12:19:41.533] ws-443-in~ ws-443-in/<NOSRV> -1/-1/-1/-1/0 0 0 - - PR-- 368/290/0/0/0 0/0 "<BADREQ>"
Meanwhile, using a browser, all requests seem to work normally.
After reading up on the web, we tried multiple options to understand these requests, but haven’t found a way to understand what these are or how they look.
The config has
enabled, allowing invalid-requests and upping the http-request timeout to 30s had no effect either.
Connecting to the socket, show errors does not show any faulty requests, which seems in line with the fact that the connection is apparently never established looking at the timers in the log above.
We initially expected these to be browser preconnects, but option http-ignore-probes had no effect either.
As soon as h2 is deactivated on the haproxy frontend, the BADREQs are gone for good.
Any ideas what could cause this? We imagine this is just noise in the logs without actual impact, but cannot say for sure.
Full config:
stats socket /run/haproxy/haproxy.sock mode 660 level admin
stats socket ipv4@172.16.xx.xxx:7167 level admin
nbproc 1
cpu-map 1 3
maxconn 1000000
ssl-default-server-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
timeout client 301s
timeout server 301s
maxconn 1000000
option log-health-checks
bind 172.16.xx.xxx:9000
stats uri /stats
frontend ws-80-in
bind 172.16.xx.xxx:80
default_backend ws-80
backend ws-80
option httpchk
timeout check 1000
server ws1 ws1.domain.net:80 weight 2 check
server ws2 ws2.domain.net:80 weight 2 check
server ws3 ws3.domain.net:80 weight 2 check
server ws4 ws4.domain.net:80 weight 2 check
server ws5 ws5.domain.net:80 weight 2 check
server ws6 ws6.domain.net:80 weight 2 check
frontend ws-443-in
bind 172.16.xx.xxx:443 ssl crt /etc/ssl/private/wildcard.domain.com_bundle.pem alpn h2,http/1.1
backend ws-443
option httpchk
timeout check 1000
backend no-match
errorfile 503 /etc/haproxy/errors/fake_404.http
Thank you all in advance!
Best
