I’ve got HAProxy running as a reverse proxy on a CentOS 7.4 box, with JIRA (Tomcat server) as the backend application and it proxies from https 443 to the non-SSL port on the JIRA server without issue.
However, on three other servers that are also running Tomcat apps on the backend, setting up the exact same reverse proxy and HAProxy haproxy.cfg (changing hosts and ports, of course) and they return 503 Service Unavailable errors. I can confirm that the Tomcat servers are up and running and accessible on their non-SSL ports so the servers are behaving exactly like the working one. This seems to be HAProxy related?
cfg is below. Any ideas?
Global settings
# need to:
# /etc/sysconfig/syslog
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
Tells HAProxy to start listening on for HTTPS requests. It uses the SSL key
and certificate found within the corp.company.com.pem file. All requests will
be routed to the confluence_http_backend
frontend confluence_http_frontend
bind *:443 ssl crt /etc/pki/tls/keystore/corp.company.com.pem
default_backend confluence_http_backend
static backend for serving up images, stylesheets and such
The confluence_http_backend simpl forwards all requests onto http://dev-wiki.corp.xperi.com:8090/.
It will only allow 1000 concurrent connections to the server at once.
option httpchk
server server01 server.corp.mydomain.com:8090 maxconn 1000
round robin balancing between the various backends
#backend app
