Dataplaneapi runtime error
There is problem if adding new site.
POST {api_url}/v2/services/haproxy/sites?version={version_nr}
Error:
{"code":500,"message":"runtime error: invalid memory address or nil pointer dereference: /usr/local/go/src/runtime/signal_unix.go:734 sigpanic"}
Error from dataplaneapi log:
level=error msg=“Panic runtime error: invalid memory address or nil pointer dereference” stack_trace="\n/usr/local/go/src/runtime/signal_unix.go:734 sigpanic\n/home/mjuraga/projects/go/pkg/mod/github.com/haproxytech/client-native/v2@v2.5.2/configuration/site.go:105 (*Client).CreateSite\n/home/mjuraga/projects/haproxytech/release/dataplaneapi/handlers/site.go:77 (*CreateSiteHandlerImpl).Handle\n/home/mjuraga/projects/haproxytech/release/dataplaneapi/operations/sites/create_site.go:84 (*CreateSite).ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/go-openapi/runtime@v0.19.15/middleware/operation.go:28 NewOperationExecutor.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/go-openapi/runtime@v0.19.15/middleware/router.go:77 NewRouter.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/go-openapi/runtime@v0.19.15/middleware/redoc.go:72 Redoc.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/go-openapi/runtime@v0.19.15/middleware/spec.go:46 Spec.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/rs/cors@v1.7.0/cors.go:219 (*Cors).Handler.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/haproxytech/release/dataplaneapi/adapters/adapters.go:145 ConfigVersionMiddleware.func1.1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/go/pkg/mod/github.com/lestrrat-go/apache-logformat@v0.0.0-20210106032603-24d066f940f8/logformat.go:65 (*ApacheLog).Wrap.func1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/home/mjuraga/projects/haproxytech/release/dataplaneapi/adapters/adapters.go:115 RecoverMiddleware.func1.1\n/usr/local/go/src/net/http/server.go:2049 HandlerFunc.ServeHTTP\n/usr/local/go/src/net/http/server.go:2867 serverHandler.ServeHTTP\n/usr/local/go/src/net/http/server.go:1932 (*conn).serve\n/usr/local/go/src/runtime/asm_amd64.s:1371 goexit"
dataplaneapi version: v2.4.4
haproxy version: 2.4.12
OS: Ubuntu 20.04
