Good morning/evening. We are using the new HAProxy dataplane API in order to perform runtime changes to the HAProxy configuration. It is working perfectly fine on one server but on another, it is generating the error “Runtime API not configured, not using it”. Due to this, the dataplaneapi binary is not able to read the /etc/haproxy/haproxy.cfg file.
Following are the details:
haproxy -vv
HA-Proxy version 2.0.5 2019/08/16 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_PCRE=1 USE_PCRE_JIT=1 USE_THREAD=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE +PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
bufsize = 16384, maxrewrite = 1024, maxpollevents = 200Built with multi-threading support (MAX_THREADS=64, default=56).
Encrypted password support via crypt(3): yesAvailable polling systems :
Total: 3 (3 usable), will use epoll.Available multiplexer protocols :
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASSAvailable services : none
[TRACE] trace./dataplaneapi
time=“2019-08-21T14:42:19+05:00” level=warning msg=“Runtime API not configured, not using it”
