from this page: https://www.haproxy.com/documentation/hapee/latest/configuration/config-sections/defaults/
If a
frontend,backend, orlistensection does not indicate a nameddefaultssection using thefromkeyword, it takes the default values specified in the nearest precedingdefaultssection.
^ The way this reads - “defaults” section use is forced.
What if I don’t want to use the “defaults” section for some frontend section? is there a way to disable this inheritance?
