Every now and then we see multiple backends flapping with this messages
is going DOWN for maintenance (entry removed from SRV record)
And sometimes when this message appears, traffic goes to BUSY for brief amount of time.
I couldn’t see any dns requests being failed, but we still see this flaps.
This is a gist of haproxy config
nbproc 1
nbthread 16
cpu-map auto:1/1-16 0-15
log /dev/log local2
log /dev/log local0 notice
chroot /path/to/haproxy
pidfile /path/to/haproxy.pid
master-worker
maxconn 200000
hard-stop-after 1h
stats socket /path/to/haproxy/stats mode 660 level admin expose-fd listeners
tune.ssl.cachesize 3000000
tune.ssl.lifetime 60000
ssl-default-bind-options ssl-min-ver TLSv1.2 ssl-max-ver TLSv1.2
server-state-file /path/to//haproxy_server_states
tune.bufsize 40960
resolvers mydns
nameserver dns1 stream+ipv4@127.0.0.3:53
accepted_payload_size 65535 # allow larger DNS payloads
timeout resolve 1s
timeout retry 2s
hold other 50000s
hold refused 50000s
hold timeout 50000s
hold nx 5s
hold valid 1s
hold obsolete 1s
frontend listener
bind x.x.x.x:80 mss 1440 alpn h2,http/1.1
default_backend server_group
server-template template_name 30 _servers-0._tcp.servers.local init-addr last,libc,none resolvers mydns check port 80 maxconn 2000 maxqueue 1
errorfile 503 /path/to/static/busy-json.http
Kindly help if we are doing something wrong !
