Hi Community,
This is my first topic
I have a problem with the configuration of an error page on haproxy version 1.8.14 … I have already configured several error pages without problems on the same instance.
The page that is creating problems unlike the other uses svg (Scalable Vector Graphics) .
The page served from haproxy is truncated (always in the same place), if I increase the tune.bufsize the problem is solved, but I do not want to increase it to avoid resource problems (possibly causing the system to run out of memory).
I thought it was a problem related to the size of http headers but I do not think this is the problem because testing a “curl -s -w % {size_header} page” the size is 260 bytes.
The page has 144k size, but I have a larger page that works correctly.
By serving the page from an apache via errorloc the problem does not occur … but I do not want to handle error pages from webserver but from haproxy …
From log i see nothing strange respect other error page :
k4m0_http_fe k4m0_http_fe/ 0/-1/-1/-1/0 403 16384 - - PR-- 5/1/0/0/0 0/0 {|} “GET / HTTP/1.1”
also with echo “show errors” | socat … nothing
Does anyone have any idea what the problem might be?
Thank you so much
K4m0
