Hi all,
I am facing strange issue , using 1 LB and 1 APP (JBOSS) server. App server having static pafe and no. of PDF files , when we click on 28K pdf file (2 pages) it will work fine.
When we click on pdf file size 90K it will show me 200 success response but pdf is not open , shows error “Failed to load PDF document” .
Initially i thaought its app server issue but when accessing pdf without haproxy all pdf is working 90K,50K…
So can some one please share is there any setting / limit set in haproxy i.e above 50K file size if yes then let me know how to increase or which parameter should i use in haproxy.conf file
