Error: failed to parse log-format : format variable 'Tq' is reserved for HTTP mode
Hi Everyone,
I’ve got a working setup where haproxy 1.8.3 successfully balances HTTP traffic. I now want to add TLS / SSL. The result should be, that HTTP and HTTPS work in parallel.
When adding a frontend section for SSL, the configuration fails with:
Parsing [/etc/haproxy/haproxy.cfg.new:27]: failed to parse log-format : format variable 'Tq' is reserved for HTTP mode.
I do have a log-format statement in the defaults:
log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %rc\ %hr\ %hs\ %rt\ %{+Q}r\ %sslc\ %sslv\ body:%[capture.req.hdr(0)]
How can I configured HTTP and HTTPS to work in tandem and keep the log format for HTTP connections?
Even if you use HTTPS, the frontend still needs to be in mode http.
Thanks! Adding mode http to the TLS frontend section resolved the error. Follow-up question: I basically want all of the health checks etc. which I’ve got in place for HTTP to be the same for HTTPS. Do I have to repeat the config directives from the HTTP section or is there any way to “combine” both sections, e.g. have one config for HTTP and HTTPS?
None of this is necessary, you don’t even need a new frontend:
Just add a new bind line for ssl:
frontend blabla
 bind :80
+ bind :443 ssl crt /path/to/certificate.pem
 default_backend backendbla
