Hello, we have problems with haproxy 1.9.4 when working with grpc.
We use bidirectional streaming of data and receive this error every 30 seconds (it’s timeout server in our configuration).
io.grpc.StatusRuntimeException: UNAVAILABLE: HTTP status code 504
invalid content-type: text/html
headers: Metadata(:status=504,cache-control=no-cache,content-type=text/html)
DATA-----------------------------
<html><body><h1>504 Gateway Time-out</h1>
The server didn't respond in time.
</body></html>
Our configuration:
option socket-stats
option logasap
option http-use-htx
timeout connect 30000
timeout client 30s
timeout server 30s
frontend main-http-grpc
description http:8080,grpc:9090
option http-use-htx
bind *:8080 name main-http
bind *:9090 name main-grpc proto h2
acl http dst_port eq 8080
acl grpc dst_port eq 9090
use_backend testhost if http { hdr_beg(host) -i testhost.local }
use_backend testhost-grpc if grpc { hdr_beg(host) -i testhost.local }
backend testhost
description http
option httpchk OPTIONS /status
server testhost1 10.10.10.1:8080 check
server testhost2 10.10.10.2:8080 check backup disabled
option http-use-htx
description grpc
server testhost1 11.11.11.1:50051 proto h2 track testhost/testhost1
server testhost2 11.11.11.2:50051 proto h2 track testhost/testhost2 backup disabled
What could be the problem?
Thanks in advance.
