I used the old configuration. (version 1.9.7). no problem.
Old config, i look haproxy_stats (LastChk in L4) is good.
but,when update to 2.2.I found GRPC-config problems.
Same configuration when I upgrade to 2.2,the configuration fails. http-grpc can not access.
2.2 config. i look haproxy_stats (LastChk in L7) is bad
I do not know problem is?how fix it.
install haproxy 1.9.7
make TARGET=linux2628 USE_ZLIB=yes PREFIX=/usr/local/haproxy
make install PREFIX=/usr/local/haproxy
------------config------------------------
frontend grpc
option http-use-htx
bind :80 proto h2
acl k8-grpc hdr_beg(host) -i test0-gogrpc.com
use_backend k8-cc if k8-grpc
default_backend xxx
backend k8-cc
option http-use-htx
server cc1 10.99.1.11:80 proto h2 check
server cc2 10.99.1.14:80 proto h2 check
