upgraded haproxy 2.1.x -> 2.2.x, everything working, almost
using haproxy as reverse proxy for apache servers
configuration for apache backends
backend default
server backend:80 127.0.0.1:80 maxconn 1000 check proto h2
for H2 apache
Protocols h2 h2c http/1.1
% curl 127.0.0.1 --http2 -I
HTTP/1.1 101 Switching Protocols
Upgrade: h2c
Connection: Upgrade
HTTP/2 200
date: Sun, 00 Jan 1900 00:00:00 GMT
server: Apache
last-modified: Thu, 27 Feb 2020 12:06:34 GMT
etag: W/“0-59f8d8d57d36c”
accept-ranges: bytes
vary: Accept-Encoding,User-Agent
content-type: text/html; charset=UTF-8
there is error log on apache backend with version 2.2.x
[Wed Aug 05 14:39:50.453929 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_filter.c(196): (104)Connection reset by peer: [client 127.0.0.1:59244] AH03046: h2_session(280): error reading
[Wed Aug 05 14:39:50.453970 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(2168): (104)Connection reset by peer: [client 127.0.0.1:59244] AH03403: h2_session(278,IDLE,0): no data, error
[Wed Aug 05 14:39:50.453979 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(1765): [client 127.0.0.1:59244] AH03401: h2_session(278,IDLE,0): conn error -> shutdown
[Wed Aug 05 14:39:50.453992 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(594): [client 127.0.0.1:59244] AH03068: h2_session(278,IDLE,0): sent FRAME[GOAWAY[error=0, reason=‘timeout’, last_stream=0]], frames=2/4 (r/s)
[Wed Aug 05 14:39:50.454021 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_conn_io.c(283): (32)Broken pipe: [client 127.0.0.1:59244] AH03044: h2_conn_io(280): pass_out brigade 24 bytes
[Wed Aug 05 14:39:50.454025 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(720): [client 127.0.0.1:59244] AH03069: h2_session(278,IDLE,0): sent GOAWAY, err=0, msg=timeout
[Wed Aug 05 14:39:50.454030 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(1675): [client 127.0.0.1:59244] AH03078: h2_session(278,DONE,0): transit [IDLE] – local goaway --> [DONE]
[Wed Aug 05 14:39:50.454034 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_conn.c(217): (70014)End of file found: [client 127.0.0.1:59244] AH03045: h2_session(278,DONE,0): process, closing conn
[Wed Aug 05 14:39:50.454039 2020] [http2:debug] [pid 205856:tid 139673980614400] h2_session.c(1675): [client 127.0.0.1:59244] AH03078: h2_session(278,CLEANUP,0): transit [DONE] – pre_close --> [CLEANUP]
version 2.1.x without any problems sending over cleartext h2 proto on apache servers
with version 2.2.x there is problem but everyhing looks same as 2.1.x (using same compile options)
: mode=HTTP side=FE|BE mux=H1
thanks for help
Pavel
