We recently upgraded to haproxy 2.2.3 from 2.0 and stared getting segmentation faults when we specify backend server with proto h2.
backend server-group
option httpchk
http-check send meth GET uri /check/path ver HTTP/1.1 hdr Host some.header
http-check expect status 200
server server1 x.x.x.x:xx check port xxx maxconn 100 enabled maxqueue 1 proto h2
errorfile 503 /path/busy.http
When we create the backend with above confing, the below error shows up in the logs and the haproxy process just stops.
Oct 30 07:51:03 hapservername[19668419.437037] haproxy[pid]: segfault at 6 ip 000055ad97b1d07d sp 00007fa4677db8d0 error 4 in haproxy[55ad97a3c000+243000]
We can fix this by changing the proto to alpn.
Below is the output of haproxy -vv
root@hapserver:~# haproxy -vv
HA-Proxy version 2.2.3-0e58a34 2020/09/08 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.3.html
Running on: Linux 4.15.0-42-generic #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018 x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE=1 USE_LINUX_TPROXY=1 USE_LINUX_SPLICE=1 USE_LIBCRYPT=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=16).
Built with OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Built with gcc compiler version 7.3.0
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
Available services :
prometheus-exporter
[FCGI] fcgi-app
Can this be a possible bug?
